fcoplo
Fernando
Argentina
Maverick Lariat FX4 South America Edition
Hi, I am looking for the new Maverick screen 2025 to start this conversion (I already did conversion to sync 4 with the original 8" screen).
I don't like the Escape screen.
I know that there are already some crashed/totaled Mavericks, but I couldn't find any sellers on eBay.
I am overseas.
Any data will help.
RONR11
Ron
Hartsville SC
2019 Ranger/Maverick
I ve had mine in about yr and no issues.
Gullzway
OK
1968 Ford Mustang Fastback
You have Lux if you have factory navigation without CarPlay plugged in.
2022 didn't have Navigation.
Ah. Thanks. No Lux here. Now... to convince the wife that I "need it"
If you have Sirius Radio and Adaptive Cruise with Lane Centering, you have the Lariat Lux.
Cactus22
B
2022 Maverick, Cactus Grey
Thanks - no adaptive cruise nor Sirius baked in.
Cactus22
B
Gullzway
OK
So, confirmed no Lux package. It is the 2022 Lariat with Sync3. Is this the right package as I don't have the Lux, I wasn't sure (it's the only one labeled Lariat):
https://oemplusupgrades.com/products/2022-2024-maverick-sync-3-to-4-upgrade-w-12-display
Only the 2022 Lariat Lux has Sync 3, with Sirius XM.
All other models Lariat, XLT, and XL have the Ford connect 2.5 radio.
https://oemplusupgrades.com/products/2022-2024-maverick-base-to-sync-4-upgrade
"Our kit works on any XL, XLT, or Lariat Maverick without Sync 3."
Cactus22
B
Cactus22
B
Ordered my kit yesterday. Going to also add a USB-C charger in the upper tray to reduce the cables going up/down since it will be Wireless Carplay.
Killerrudy
B rian
Ohio
2023 Maverick
Finally got around to attempting to program my install yesterday. 21' F150 apim and 23 lariat Maverick ACM into my 23 XLT. So I copied over Bobert47's built from back on page 19. I was fighting getting my GPS to work correctly. This resolved that issue with it jumping around madly. So now I am only down to two problems. Both my usb ports no longer function (saw they are controlled from the ACM(will have to investigate that)) and secondly my volume knob works, but the screen pop up never changes from 0. All the other buttons work and display the information as they are supposed to. Seeing if someone had some directional guidance. Thank you
Bobert47
Bobert
Kentucky, US
2023 Ford Maverick Lariat
Happy to have been a help! The volume knob working but showing zero I also ran into at first, it was a cluster group selection when I was adjusting radio and hvac configs, so I'd look there first. For the USB ports, I'd double check you don't have a loose pin or wire in your harness to the APIM (I ran into that once as well). Sounds like you're most of the way there 👍
Killerrudy
B rian
Ohio
2023 Maverick
Thanks for the quick reply. I didn't think to check the wiring for the USB not working as it was one of those pre built harnesses that I got thru here. Well after I missed that there was a group discount of course.. 😞
yeahiguessman
Angelo
2024 Maverick Lariat
Anybody running into audio settings like EQ resetting after restarting the vehicle?
Cactus22
B
Mine sticks. I got it pre programmed from OEM, and everything is working (other than nav - known issue). It all works as expected
