pantera156
Pantera
Porto Alegre
lariat 2.0
I do also, like Bill said just ignore
DE07/7D0-08-01: xxxx-xx00-xx--
DE07/7D0-08-01: 0xxx-xxxx-xx--
DE08/7D0-09-03: xxxx-xxxx-x0--
DE07/7D0-08-01: x0xx-xxxx-xx--
DE00/7D0-01-03: x0xx-xxxx-xx--
Solved!
That cancels everything related and there is no more error.
pantera156
Pantera
Porto Alegre
lariat 2.0
Would it be possible for APIM to show thrips like this?
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_0200
yeahiguessman
Angelo
2024 Maverick Lariat
Unfortunately, on my end I tried two separate APIMs from 2024, two different harness’s, two separate USB cables, and a million different ForScan adjustments, but no matter what I still have audio crackling through Bluetooth or USB audio. Tried an APIM from 2021 running on very old firmware and it worked perfect, but lose some of the newer look and full screen CarPlay. I’ve kind of given up on it as a whole as it seems this mod just doesn’t want to play nice with my ‘24 Hybrid.
Was a fun try though! Cool to get it so close.
Toddman45
St. Louis, MO
Looks 5x better than the OEM 8" & cubby. I wish a member would sell a pnp harness along with detailed install. As im too lazy to make up my own.😎
pantera156
Pantera
Porto Alegre
lariat 2.0
Could it be that the problem is the ACM and not the APIM? :inspect:
yeahiguessman
Angelo
I just would think it odd that the ACM has no issue with the 2021 APIM or the Mavericks original. Just these two 2024 APIMs.
yeahiguessman
Angelo
What software version are you guys running? Both of the 2024 APIMs I had that are acting up are running this one. Trying to figure out if it’s a hardware revision that caused some communication issues with the ACM or a possible software bug. Would be helpful to let others know what to avoid in the future!
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) IMG_0686
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
I did not have it showing anything until I swapped my gauge cluster to one from a 23 escape. Now they talk to each other and I get all that info
Billzilla15
Billzilla15
Ohio
22 Maverick Lariat
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) PXL_20250117_112703152
That's a really good point, I forgot about that. I had a XLT and Sync3 on my Lariat was a big step up so Sync 4 is a giant step up. Ford Connected Audio felt like 2005.
I have a hybrid XLT and Lariat. Everything seems to be slower in the XLT than the LARIAT, brings up the question "Is the main CPU identical in all trucks with the clock speed set slower in the XLT or if different cpu's can main boards be swapped?".
yeahiguessman
Angelo
Yeah, I feel like this has to be a software bug. Two of my APIMs running the same software having the same issue while one running much much older software doesn’t have that issue at all?
Feel like I’d be better off buying a Mongoose and power supply and updating overnight using FDRS rather than trying to find another APIM.
pantera156
Pantera
Porto Alegre
lariat 2.0
Ford Maverick Sync4 APIM and 13.2" Screen Installation Guide (Lariat Models) photo_2025-01-18_00-59-32
