protijy
Scott
Bentonville, AR
Finally got to this project:
VAIR 12v 23amp 2CFM (enough to seat a tubeless Mtb tire)
Hard mounted into the bed cubby
Wired directly to the 12v battery under the rear seat in the hybrid. I installed a 30amp fuse inline to the compressor. Routed the wiring along the factory harness above the fender well, and thru one of the body vents into the backseat.
Nice and clean fits like a glove!
Ford Maverick Stealth onboard air compressor install in bed. IMG_8465
Ford Maverick Stealth onboard air compressor install in bed. IMG_8466
Ford Maverick Stealth onboard air compressor install in bed. IMG_8469
Ford Maverick Stealth onboard air compressor install in bed. IMG_8474
Ford Maverick Stealth onboard air compressor install in bed. IMG_8468
Ford Maverick Stealth onboard air compressor install in bed. IMG_8473
Ford Maverick Stealth onboard air compressor install in bed. IMG_8475
Ford Maverick Stealth onboard air compressor install in bed. IMG_8476
Ford Maverick Stealth onboard air compressor install in bed. IMG_8478
Ford Maverick Stealth onboard air compressor install in bed. IMG_8470
Ford Maverick Stealth onboard air compressor install in bed. IMG_8471
Toymaster
Wyoming
2025 XL hybrid AWD, Bronco, Superduty, Explorer
Sweet. On-board air is awesome. Last week I picked up a nail in the factory conti's, hadn't stocked the truck yet and had to borrow stuff to plug the tire. I hate being the helpee instead of the helper. Now I have a plug kit and a portable viair 89P that lives under the rear seat.
dochawk
doc
Las Vegas
he pulls over, repairs a flat tire, inflates it, and takes off into the night before the stranded motorist can even thank him.
Who was that gassed man?
:teehee:
Cancunbadlands
Cancun
Cancun
Is it water proof?!
Nibyak
Virginia
2025 XLT
Carlitos_92
dumbcomputers
The Earth
2025 Maverick Lariat Hybrid
I've had this one under the seat for a couple of years, and while it isn't "heavy duty," I like that it has SAE and 120V power, as well as a shutoff when it reaches the set PSI. In my experience the PSI readings are at least as accurate as the TPMS...
https://a.co/d/041N5gAV
I originally bought mine to use at the track when I used to race my car. Since then I just keep it in the car I do most of my road-tripping in.
I also have two compressors in my other car...haha
Ford Maverick Stealth onboard air compressor install in bed. chB4ebI
