SnyperX's Stereo Upgrade Thread
SnyperX
Wisconsin, USA
2024 Ranger XLT Sport 2.3L
I am starting my stock stereo upgrade journey and figured I would start a thread to track my project. I have the gear I will be installing at this point and hope to start installation in the next week or two. Will be updating my post as I progress.
Head Unit: Stock
Front Speakers: PowerBass OE65C-FD $130
Rear Speakers: Pioneer TS-G400 $60
Subwoofer: Kicker Hideaway 8" $270
Line Converter: AudioControl LC2i $100
Misc.: Kicker KISL Adapter $17
Plug 'N' Play Kits LC2i Harness $90
Scosche Extape
Bojo Trim Panel Tools
S'mart Mat 90 Mil Sound Deadener $25
Sound Deadener Roller
Front Door Speaker Upgrade
So this weekend I was able to get the front speakers installed. In this section I am going to try and highlight what I experienced.
Driver/Passenger Door Panel Removal
First off, WORK SLOW AND TAKE YOUR TIME as this will reduce any potential damage to plastic pieces and the various clips. Start at the top and corner of the door and pop off the black cover. 1 metal and 2 plastic clips need to be released. Next, at the top of the door panel, remove the cover behind the door handle pull. DO NOT use a screwdriver, but make sure to have a set up panel removal tools. The bolt behind the panel is an 8mm.
Ford Maverick SnyperX's Stereo Upgrade Thread B79AC909-547C-4869-ABD0-56C070E4F5F1
Ford Maverick SnyperX's Stereo Upgrade Thread E5E2525F-B743-41F7-A653-EC7DC7093DB2
Ford Maverick SnyperX's Stereo Upgrade Thread 34825DBC-E29A-455E-9926-76BFD93D68E1
Next, you will need to remove the window switch panel. Start on the left side of the panel and work your way around to the front. The panel has about 3 clips that need to be released to get the panel out. Once out you can easily unplug the panel to get it out of the way. Once this is done you will see the two bolts that need to be removed. I believe they are 7mm.
Ford Maverick SnyperX's Stereo Upgrade Thread EFF48564-52A8-4825-BF03-7A67E36E140D
Ford Maverick SnyperX's Stereo Upgrade Thread 63DA82A1-9664-4C09-9FF5-2D58DBC240F8_1_201_a
Moving on to the bottom edge of the door panel you will have 3 7mm bolts/screws that need to be removed. 2 of the bolts are along the bottom edge the third one is behind the red "reflector"
Ford Maverick SnyperX's Stereo Upgrade Thread 84830AAD-2ECB-41D2-B957-9C89080F6A7C
Ford Maverick SnyperX's Stereo Upgrade Thread 48E74482-7B73-4FAB-9678-C3C1633DCB45
Ford Maverick SnyperX's Stereo Upgrade Thread 9F9B47BB-F7D8-4F42-AC10-2934B153CF3D_1_201_a
This next step is the most likely to cause broken clips. You need to now work to release the door panel from the door skin. Starting at the BOTTOM and right side of the panel and using your panel removal tools work to create a gap between the door panel and the door skin that will allow you to get a finger hold on the door panel. Using a pretty good amount of force work to start releasing the plastic door clips that continue to hold the door panel to door skin. It will take a good amount of force and it is likely that a clip or two will break (I only broke one between the passenger and driver side). I believe there are 4 clips that need to be popped free. Once all the clips are all popped you should be able to lift the door panel up and off the inner door skin. Keep in mind the door handle/lock mechanism will still be connected. It's a bit tricky to remove the fragile plastic piece that holds the cables, but can be done with care and allows the panel to be fully removed from the door to allow you to work freely on the door panel (I did this to install my sound deadener).
Ford Maverick SnyperX's Stereo Upgrade Thread 43FE9463-87C6-4F17-AC06-1852C3ED11DF_1_201_a
Once the door panel is fully removed it is as easy as removing 3 7mm bolts to remove the stock 6.5" door speaker and replace. Since I am using the PowerBass speakers it was plug and play. Reverse install to re-assemble.
Ford Maverick SnyperX's Stereo Upgrade Thread AFE89F6F-2098-4602-8352-BAAC132C2F65
Ford Maverick SnyperX's Stereo Upgrade Thread 4410EC3D-E4F1-45A6-BD3C-46EAF8F000AE
robb01
Looking forward to pics! Where are you installing the Kicker? Was wondering if it'd be possible to go under the driver/pass seat?
Tazgarde
Travis
Brampton, Ontario
2023 Ford Maverick XLT Hybrid2015 Honda CBR300RA
I'm interested!
SnyperX
SnyperX
Wisconsin, USA
I am likely installing on the back wall passenger side.
Hammer
Easton PA
2009 VW GTI
SnyperX
SnyperX
Wisconsin, USA
kahuna_08
Milwaukee, WI
will you be tapping into the rear speakers or running a cable to the head unit?
SnyperX
SnyperX
Wisconsin, USA
That is the current plan then using the AudioControl LC2i to hook the Kicker into.
Hammer
Easton PA
2009 VW GTI
Updated my OP with prices.
Thanks ! Looking forward to see your progress and how you rate the sound from the completed build.
MaverickShark
Sal
San Jose, CA
Maverick XLT Hybrid 2022 Mitsubishi Outlander 2017
I am looking into the kicker hideaway 8" or 10". Definitely interested how it sounds on the back wall with the seat covering it. Hope you post a video with audio that can pic up those low frequencies.
BootXL76
Josh
Arkansas
2022 Maverick XL
Get the 10 if you get one of the two, the 8 is solid but odds are you’ll wish you got the 10…. (I was mostly happy with the way the 8 sounded back there, it just wasn’t able to hit certain lower tones that I want)
SnyperX
SnyperX
Wisconsin, USA
I really considered the 10", but being I am a hard rock guy I wanted the bass to be more short and punchy and less long and boomy.
Red Ryder
United States (TN)
22 Maverick XLT Iconic Silver
That's my genre too. Maybe I should have went with the 8", or one of the JL microsubs and an amp.
Definitely not looking for boomy. I want tight, punchy bass. And I don't need a ton of it either.
uh50
Howard
www.hchaney.com
2022 Maverick XL, VB, 2.0 EB
Head Unit: Stock
Misc.: Metra 72-5600 Rear Speaker Adapters
Kicker KISL Adapter
Scosche Extape
I've just about decided on the Powerbass OE65C-FD for front speaker replacement, but undecided on the rears, so I'll be very interested to find out what you think of the TS-G400 Pioneers.
Thinking seriously about a 6" x 9" JBL GTO Component and installing the 6 x 9s under the rear seat and the tweeters to replace the 4" rears, then adding a JBL Nano powered 6" x 8" sub. Also thinking of using JBL 6.5" Components for the front instead of the Powerbass, but not sure.
Anyway, looking forward to your posts about your system and what you discover.
