Small Snow Plow on a Maverick - can I, Should I ?
Rmacdoug
Stroudsburg PA
buying my first Ford truck
Well, my 2024 Maverick AWD (ordered in Sept 2023, not being build until Feb 2024) did not come in time for the 10 inches of snow on my driveway.....but it does beg the question...can this size truck take a small snow plow? I live in the Poconos and it looks like this winter will have actual snow....
I wouldn't do it, but I'm sure someone is going to jump in with a reply that they have a snowplow on their Subaru. There is nowhere good to mount it on the front of a Maverick and even if you welded on a bracket, let's say similarly to how a tow-behind kit works, it will definitely bend the frame given enough time.
Could you get away with it just a few times on a smooth, fairly level driveway? Probably yes. But
I would use a snowblower or tractor if I had a serious need for snow removal, like Buffalo NY.
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Do you have a snow blower or power shovel? Even this snow sport hitch plow is 1300. Seprately, Not sure if the Mav can use the $500 "nordic plow" auto plow. Seems like you could get a snow blower for a similar price. I did get small power shovel (Toro plug-in) this year but that sounds like a blower job.
https://www.sharptruck.com/access-c...sYD1Yc_0ocz-JgJgfBMLqFWNZSo4Z8fRoC3roQAvD_BwE
Traegorn
Trae
Eau Claire, WI
www.nerdandtie.com
2023 Ford Maverick XLT Hybrid Lux/360
I don't know about hitch mounted snow plow, but I know that the manual says explicitly not to mount one to the front. This is likely because it doesn't have a traditional frame, so it can't handle the pressure on the body.
Snox801
Levi
Spring Lake Michigan
I think you need to use your own judgment.
If someone comes out with a lot why not. People use all kinds of stuff here to snowplow. Just because the manufacturer says not to does not mean it can’t. I had several f-150’s that said not to. Only reason was the charging system.
Could be many reasons. Would I take on accounts with a maverick nope. But moving up ur own snow without getting rough on it should be fine. Most light duty plows also have springs rates for that.
Rmacdoug
Stroudsburg PA
so, the easy answer is...no....don't dare try....it'll really screw up the Maverick.....
Got it.. THANKS EVERYONE. (I was leaning toward getting a stand alone snow blower anyway......with all this great advice...THAT IS WHAT I'LL DO!!!) Cheers....a (hopeful) future Maverick owner....
Bob The Builder
Butch
Vermont
Oh, my, no. Don't do it even if you can. Just don't. o_O
Executech
Matthew
Ford maverick
I’ve looked at this a lot and I do not do it, but…
it seemed like you may be able to buy a Meyer home plow and put it in your rear hitch and go in reverse. The thing is, maybe it’d be fine once a year, but then that means you wouldn’t have to do it often so spending the money on a snow plow or hiring someone to plow your driveway is a better option.
I have a 300ft driveway and chose to get a quad with a plow to clear snow, plus I use it for other things as well.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Way back in early 2022 I saw a picture of a Maverick with a small plow, but to much info on it. Someone even had a small plow on the rear f the truck.. wish I’d try to catch pictures.
BradnChristine
Brad
Wyoming
Instead of my Maverick, my wife does a fine job of moving snow. She is sturdier than the front end of the truck (and also she does not see what I post on this board).
Ford Maverick Small Snow Plow on a Maverick - can I, Should I ? 1704760820443
