GadgetDad
Jeff
Toledo Ohio
22 Maverick - Alto Blue FX4 4k Tow Lariat Lux 360
Wife has the truck right now...is there a dipstick to check fluid level? Our caravan fluid is lifetime.
You have to access it under the vehicle to check fluid levels of the transmission. For me that’s difficult without a lift. I have them check it at each oil change now.
Tim d
Alpena
Ram
Ug,don't know why they are doing away with the dipsticks.i like to check the color periodically on my rams fluid.
Phimosis
Larry
Santa Clarita, CA
Seems weird the engineers went thru all the trouble and time to make all these changes and no difference in hp or mileage.
Not weird at all. Current engine won’t meet 2027 EPA emissions standards.
Same cycle that has been happening since 1970 when the EPA first started regulating tailpipe emissions.
Back in the early 70’s, the air in big cities looked like brown soup. Kid’s IQ’s were on average, 6 points lower because of leaded gas. A large percentage of non-smoking city dwellers had chronic cough from asthma like symptoms due to air pollution. Sitting in traffic would make your eyes water from exhaust fumes. People were dying at a younger age from heart disease caused by fine (pm10) inhaled hydrocarbon particulates.
I welcome these changes. We have the technology to support the stricter regulations. Air is 78% cleaner in 2025 than it was in 1970.
Ford Maverick Significant changes to the 2025 2.0 Ecoboost Engine IMG_2771
Ford Maverick Significant changes to the 2025 2.0 Ecoboost Engine IMG_2770
Ford Maverick Significant changes to the 2025 2.0 Ecoboost Engine IMG_2768
HenryFord
HenryFord
MO
Most of that reduction was due to outsourcing our manufacturing! You are spot on 2027 is the next round of crackdowns with 2030 basically ending most new ICE manufacturing unless they come up with some sort of miracle to address emissions.
If they were serious about reducing the particulate emissions in gas cars they would roll back to port injection which does not have the particulate problems of GDI. They will be erasing the gains that GDI brought with the addition of GPF. Ask anyone who owns a diesel. Sometimes you have to remember why you went into the swamp in the first place...
If one is that serious about the air quality today there is no reason you can't be in an EV right now.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
I think the biggest news on engine is port injection added. No more oil catch can needed. No more dirty intake valves.
A catch can was never needed, as there has always been one built onto the side of the block on all 2.0 engines since 2013. People who added one don't like being told that they wasted their money and will swear that they needed it.
Tim d
Alpena
Ram
Didn't realize all that work was done just for emissions
stangg17
Chicago
I feel personally insulted 😂
Boosted
BoostedMaverick
2024 Ford Maverick EcoBoosted Tremor w/Terrain
None of this matters to me LOL, I have port injection and tossed that noisy high pressure fuel pump on my 2024. I couldn't hear it anyways with my Catless Downpipe and Exhaust system
Tbone289
MO
Don't you find it odd that the factory oil separator leaves enough vapor exiting through the PCV that additional aftermarket catch cans catch it so it can be drained off? It seems to me that the factory oil separator isn't perfect at trapping crankcase vapors.
BTW, Mazda/Ford 2.0 engines have had oil separators since well before 2013. The Ford 2.0 Zetec prior to that even had one.
HenryFord
HenryFord
MO
I debated doing this when I bought my 23 ecoboost, but didn't think Ford would design an engine that needed this!
Unfortunately all the manufacturers rushed out the door with GDI without considering the consequences. It has just taken some of them A LOT longer to get around to correcting it. People are like, but my truck runs fine... Give her time. Atherosclerosis takes time. She is getting plugged up. A catch can or in this case a side reservoir area in the engine only slows the effect. So now we are back to injecting fuel into that intake. But since they still insist on direct injection the particulate matter issue still exists which forces them to deploy the GPF. Port injection alone doesn't have this issue. Seems like 1 step forward 2 steps back.
Tim d
Alpena
Ram
Good points to consider since I keep my vehicles a long time.
Master Blaster
Master
Toronto
Isn't it odd that the factory oil separator leaves enough vapor exiting through the PCV that additional aftermarket catch cans catch it so it can be drained off?
An aftermarket catchcan does not trap much other than water vapour or aromatics, which are otherwise just ingested into the PCV as intended. People who claim to be catching fluids are for the most part just collecting water and some blow-by gasoline fumes when they cool further in an external can. However, there are a couple with broken rings or valveguide seals that need to have an engine rebuild, probably due to overrevving it. There are one or two who like to live at the redline that are catching something, but they just need to fix their attitude issues. They're for really loose race-only engines, not street ones. 99% of owners do not have a valid use for an additional catchcan, but they will swear that it does something fantastic after spending hard-earned money and time installing it.
P.S. I sold my 2.0 EB with 189k on the odo and the intake valves were clean at inspection. Its all about the fuel and oil quality that you feed it.
Tbone289
MO
A catchcan does not trap much water vapour of aromatics, so they are just ingested into the PCV as intended. People who claim to be catching fluids are for the most part just collecting water and some blow-by gasoline fumes when they cool further in an external can. There are a couple with broken rings or valveguide seals that need to have an engine rebuild, probably due to overrevving it. There are one or two who like to live at the redline that are catching something, but they just need to fix their attitude issues. Its for really loose race-only engines, not street ones. 99% of owners do not have a valid use for an additional catchcan, but they will swear that it does something fantastic after spending hard-earned money and time installing it.
That's quite a diatribe about people's driving habits. This clearly is something you're passionate about, because I've seen you comment about it many times.
Have you ever considered that some people want their intake charge to be clean as possible, regardless if they're racing or not? I've never seen a single PCV valve or hose that was completely void of oil on any vehicle I've worked on, including many Mazda/Ford 2.0s, so clearly oil separators aren't 100% efficient. I've also not seen anyone exclaim that a catch can does something "fantastic", I've only seen people claim that it keeps crankcase vapors cleaner, which it does.
