I sure do. I want to make sure folks are aware of their options, especially if someone's new vehicle is in the shop for over 30 days with no resolution.
I still think it’s an issue the the case bushing/bearing. Still need to argue with dealership more but if I don’t get any resolution I’m going to replace the bushing myself. Will post updates as they come. Appreciate the input from everyone.UPDATE: Just got off the phone with the Ford Customer Service Rep. They said that the Ford Engineers have determined that the wobble “it’s a characteristic of the Maverick” and there is no further action they will be taking.
I told them that I have no idea how they could possibly come to that conclusion if they’ve never looked at anything on my Maverick except for rebalancing the rear tires when I first took it in just before Christmas. Nothing else was ever looked at.
I’m open to suggestions on a path forward.
When you have the axle out, check the case bearing/bushing if you can. I’m not 100% that it is the issue with mine, but I’m fairly certain that’s where my problem is coming from. Below is the part I’m talking about.Current 23,500 miles. Lift went on very early 4k. No issues initially…. Developed the wobble around 12k. I have the wobble…. Again. 2” lift… 245/70/17. Ford replaced the right front axle under warranty due to a leaky inner boot…..but was annoyed about it being lifted…The tech never mentioned it to service. Wobble went away for 8k, a week or so ago…wobble came back hard. Notice it under acceleration out of a turn. Also has Leaky right axle boot again. Dropped off to Ford. Dealer denied replacement again, blaming lift this time.
Replacing the axle myself this week, see what happens.
It was 100% my axle. My 2” spacer lift put my axles at such a drastic angle. One photo is my spacer lift, the other is with Eibach Spring lift. Replaced right front axle, swapped lift kits and an alignment today. No more wobble for now.When you have the axle out, check the case bearing/bushing if you can. I’m not 100% that it is the issue with mine, but I’m fairly certain that’s where my problem is coming from. Below is the part I’m talking about.![]()
Were those pics taken while the truck is on a ship lift or is it sitting on the ground? The angle is way more drastic than mine.It was 100% my axle. My 2” spacer lift put my axles at such a drastic angle. One photo is my spacer lift, the other is with Eibach Spring lift. Replaced right front axle, swapped lift kits and an alignment today. No more wobble for now.
I agree that the life will cause more wear than normal, but 2” doesn’t seem like it would cause what we are experiencing so quickly. There are a few folks without the lift experiencing similar issues.Interesting. Recent '23 owner and have been looking at lifts/leveling and drops folks are doing on these Mavs. The lift angle difference in the CV shaft surely could be prematurely wearing these out slowly over thousands of miles. Once warped, it would just get worse. Perhaps a slightly more resilient bushing can be made since it is a quite a simple part? A 2" lift may not seem like much, but for a short rotating shaft, 2" can actually be a lot to compensate for (I can already hear the "that's what she said" reply coming).
Full Droop on liftWere those pics taken while the truck is on a ship lift or is it sitting on the ground? The angle is way more drastic than mine.
This is a pic of my front left with the wheel turned all the way to the left. Not even close to what you have (if the pics were taken with the truck on the ground).
I'm wondering if this is what Customer Service meant:UPDATE: Just got off the phone with the Ford Customer Service Rep. They said that the Ford Engineers have determined that the wobble “it’s a characteristic of the Maverick” and there is no further action they will be taking.
Hoping my axels don't hate me- Put the H/R springs on about 3 months ago.It was 100% my axle. My 2” spacer lift put my axles at such a drastic angle. One photo is my spacer lift, the other is with Eibach Spring lift. Replaced right front axle, swapped lift kits and an alignment today. No more wobble for now.
I’m not really feeling anything in the steering, mainly in the seat/floorboard. Just a smooth, medium speed side to side wobble, not fast or slow movement.I'm wondering if this is what Customer Service meant:
'The EPAS system has a Pull Drift Compensation (PDC) feature to assist drivers in compensating for variation in road and driving conditions. The feature adjusts power assist offset by reducing the steering wheel effort (input torque) required to keep the vehicle traveling straight. The Pull Drift Compensation (PDC) feature is automatically enabled at vehicle speeds above 40 km/h (25 mph) with sensors indicating the vehicle is traveling straight. Pull Drift Compensation (PDC) is designed to compensate for variations in road crown'.
I haven't got my Maverick yet (maybe next month) but I'm wondering if you can feel the gremlins pulling at the steering when Land Centering and PDC is active.
