Shimmy/Wobble
bgn
WA
I sure do. I want to make sure folks are aware of their options, especially if someone's new vehicle is in the shop for over 30 days with no resolution.
NycGoose
Devin
Cooperstown
Maverick, tacoma, bmw 325 89
I began to notice it way more in the 12-18k range oddly and it definitely is less bad now that the weather is warming up. Im planning on having my dealership take a look when i bring my mav in for its 20k check up
90south
90south
Missouri
2022 Maverick Lariat AWD
UPDATE: Just got off the phone with the Ford Customer Service Rep. They said that the Ford Engineers have determined that the wobble “it’s a characteristic of the Maverick” and there is no further action they will be taking.
I told them that I have no idea how they could possibly come to that conclusion if they’ve never looked at anything on my Maverick except for rebalancing the rear tires when I first took it in just before Christmas. Nothing else was ever looked at.
I’m open to suggestions on a path forward.
207maverick
Maine
Ford maverick 2022
I still think it’s an issue the the case bushing/bearing. Still need to argue with dealership more but if I don’t get any resolution I’m going to replace the bushing myself. Will post updates as they come. Appreciate the input from everyone.
amargolin91
Andrew
Pennsylvania
Current 23,500 miles. Lift went on very early 4k. No issues initially…. Developed the wobble around 12k. I have the wobble…. Again. 2” lift… 245/70/17. Ford replaced the right front axle under warranty due to a leaky inner boot…..but was annoyed about it being lifted…The tech never mentioned it to service. Wobble went away for 8k, a week or so ago…wobble came back hard. Notice it under acceleration out of a turn. Also has Leaky right axle boot again. Dropped off to Ford. Dealer denied replacement again, blaming lift this time.
Replacing the axle myself this week, see what happens.
207maverick
Maine
Ford maverick 2022
When you have the axle out, check the case bearing/bushing if you can. I’m not 100% that it is the issue with mine, but I’m fairly certain that’s where my problem is coming from. Below is the part I’m talking about.
Ford Maverick Shimmy/Wobble IMG_0614
mots
mots
USA\Midwest
2023 Maverick
Interesting. Recent '23 owner and have been looking at lifts/leveling and drops folks are doing on these Mavs. The lift angle difference in the CV shaft surely could be prematurely wearing these out slowly over thousands of miles. Once warped, it would just get worse. Perhaps a slightly more resilient bushing can be made since it is a quite a simple part? A 2" lift may not seem like much, but for a short rotating shaft, 2" can actually be a lot to compensate for (I can already hear the "that's what she said" reply coming :ROFLMAO:).
amargolin91
Andrew
Pennsylvania
It was 100% my axle. My 2” spacer lift put my axles at such a drastic angle. One photo is my spacer lift, the other is with Eibach Spring lift. Replaced right front axle, swapped lift kits and an alignment today. No more wobble for now.
Ford Maverick Shimmy/Wobble IMG_6512
Ford Maverick Shimmy/Wobble IMG_6523
207maverick
Maine
Ford maverick 2022
Were those pics taken while the truck is on a ship lift or is it sitting on the ground? The angle is way more drastic than mine.
This is a pic of my front left with the wheel turned all the way to the left. Not even close to what you have (if the pics were taken with the truck on the ground).
Ford Maverick Shimmy/Wobble IMG_0615
207maverick
Maine
Ford maverick 2022
I agree that the life will cause more wear than normal, but 2” doesn’t seem like it would cause what we are experiencing so quickly. There are a few folks without the lift experiencing similar issues.
amargolin91
Andrew
Pennsylvania
Full Droop on lift
rivermaverick
Fort Mohave AZ
I'm wondering if this is what Customer Service meant:
'The EPAS system has a Pull Drift Compensation (PDC) feature to assist drivers in compensating for variation in road and driving conditions. The feature adjusts power assist offset by reducing the steering wheel effort (input torque) required to keep the vehicle traveling straight. The Pull Drift Compensation (PDC) feature is automatically enabled at vehicle speeds above 40 km/h (25 mph) with sensors indicating the vehicle is traveling straight. Pull Drift Compensation (PDC) is designed to compensate for variations in road crown'.
I haven't got my Maverick yet (maybe next month🤞) but I'm wondering if you can feel the gremlins pulling at the steering when Lane Centering and PDC is active.
Nw_adventure
Salt Lake city
Hoping my axels don't hate me- Put the H/R springs on about 3 months ago.
90south
90south
Missouri
I haven't got my Maverick yet (maybe next month🤞) but I'm wondering if you can feel the gremlins pulling at the steering when Land Centering and PDC is active.
I’m not really feeling anything in the steering, mainly in the seat/floorboard. Just a smooth, medium speed side to side wobble, not fast or slow movement.
I can see there are different things that might make this happen BUT…outside of them test driving and rebalancing the rear tires I’m not too sure that they have ever opened the doors on it again. It’s always in the exact location as where I parked it. Seems they just want Ford to tell them what to do and in what order. So when Ford says “characteristic of the Maverick” they say “ok, nothing to fix here”.
I requested the Ford Rep to contact another fairly local Ford dealership and grease the skid for me to get it in to them. She did and I’m taking in to them tomorrow.
