??? I did that's why I ask.No. Do it in your truck.
You can thank me later.
I only know it works in XLT hybrid.??? I did that's why I ask.
Therein lies the problem.The seat-belt reminder comes on whether you put on a seat-belt or not, just shows a green seat instead of red. You still have to click OK on the steering wheel to make it go away, even if you have it on.![]()
It is. Lariats and FX4s/Tremors have the larger productivity screen IPC which has an option to disable the seatbelt screen.Thought it was just a difference between screen sizes since other screen menus are different too.
I see you have a 2022. I have a 2023 Lariat. In the Info cluster on dash, there is a screen for seatbelts, but if it is unchecked, I still get the "Seatbelt Warning" window popup like in first post of this thread. I have looked in cluster settings as well as the touchscreen above center console for a setting to turn off, but do not see one, unless I'm just missing it.It is. Lariats and FX4s/Tremors have the larger productivity screen IPC which has an option to disable the seatbelt screen.
In that case it's because the seatbelt is unbuckled but an occupant is detected. XL/XLT owners are typically complaining about the seatbelt status screen that comes up on startup even when buckled.I see you have a 2022. I have a 2023 Lariat. In the Info cluster on dash, there is a screen for seatbelts, but if it is unchecked, I still get the "Seatbelt Warning" window popup like in first post of this thread. I have looked in cluster settings as well as the touchscreen above center console for a setting to turn off, but do not see one, unless I'm just missing it.
This is a overly litigious world we live in, thank the lawyers.....The Maverick is really overly obsessed with the seatbelts. I've just used the truck for Ubering the last 3 days, and it's extra annoying to have this seatbelt warning every single time someone gets in and out of the truck. Another thing is that the truck doesn't complain if someone gets in the back seat and does not buckle up, but if they do buckle up, then unbuckle, the seatbelt warning chime goes crazy. It won't stop until they either buckle again or get out.
I thought that might be it, because I usually press "Start" before putting on my seat belt. I just went and tried it out. I sat in the seat, put on seat belt first, then pressed "Start." That window still popped up, just showing that I had seat belt on. And... begging me to press "OK",In that case it's because the seatbelt is unbuckled but an occupant is detected. XL/XLT owners are typically complaining about the seatbelt status screen that comes up on startup even when buckled.
@tkistre is correct, my 2023 Lariat sends up the seatbelt screen every time, even when I'm buckled before pushing start. I cannot find a way to disable this.In that case it's because the seatbelt is unbuckled but an occupant is detected. XL/XLT owners are typically complaining about the seatbelt status screen that comes up on startup even when buckled.
