SeatBelt Splash Screen: Has Anyone Tried This
EONR24
Swag
United States
2024 Ford Maverick XL
Mavrik23
Rob
Cary, NC
2023 Maverick XLT Hybrid
Hello everyone!
I finally found the way to disable the ANNOYING Seatbelt information screen that comes on when you start the truck and stays on even after you buckle your seatbelt. Thank you to 2023 F250 forums for the coding information.
DISABLE SEATBELT INFORMATION SCREEN
1. Open IPC AS BUILT
2. Change line 720-13-01 and 720-13-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
3. Change line 720-14-01 and 720-14-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
These coding changes worked for my 2024 Maverick XL AWD ECOBOOST. These changes remove the seatbelt information screen entirely and also seemed to disable the seatbelt chime all together. I would love to hear from other members to see if these changes work in your Maverick! Also, I have the smaller instrument cluster. (The 4 inch Instrument Cluster)
If I wanted only to remove the popup display and keep the chime, would I change 720-13-xx or 720-14-xx? Thanks.
EONR24
Swag
United States
I will do some code testing and see if there is any belt chime at all now and I’ll get back to you about if it’s possible to disable the seatbelt screen but keep the dash light and chime.
My first thought is to enable driver and passenger belt minder in the body control module easy mode in addition to the IPC coding I provided.
Mavrik23
Rob
Cary, NC
Thank you, I look forward to your testing and response.
nicobonis
nicobonis
Nicolás
Banfield - Buenos Aires - Argentina
Ford Maverick Tremor 2025
EONR24
Swag
United States
If you would like to keep the Minder (the dash light and chime) and not the Monitor (the seatbelt screen) I would suggest doing the following coding based on this code diagram and my original coding in my Maverick.
720-13-01 9100 0001 8000
720-13-02 0110 1000
720-14-01 1000 0000 0000
720-14-02 All Zeros
Mavrik23
Rob
Cary, NC
If you would like to keep the Minder (the dash light and chime) and not the Monitor (the seatbelt screen) I would suggest doing the following coding based on this diagram and my original coding in my Maverick.
720-13-02 0110 1000
720-14-02 All Zeros
EONR24, Thank you so much! Worked like a champ on my '23 XLT Hybrid. The Minder is preserved and the Monitor is gone..
Also thank you for providing the code decipher. As a software engineer, I usually like to see these things to understand the changes before I go and make them. Bravo!
nicobonis
nicobonis
Nicolás
I´ll will give it a try today or tomorrow, Thank you so much guys for sharing this info with me.!!!
nicobonis
nicobonis
Nicolás
720-13-02 0110 1000
720-14-02 All Zeros
People this works awesome!! here is the solution! thank you Eorn24
EONR24
Swag
United States
Hey what size dash screen do you have 4inch or 6.5 inch?? Thanks.
