Rear Seat Not Latching
BretMaverick
Stan
Albany NY
Jeep Cherokee, Subaru Forester, Audi A5 Cabriolet
Picked up my velocity blue Maverick Lariat with Lux Pkg. It was a long time coming. I had ordered on June 21. Very satisfied with the vehicle and the dealer. Bought it from Depaula Ford in Albany New York.
Ok, back to the topic. When I got home with the Maverick on inspection my son noticed the rear seat was not latching. It did not seem to be a big problem and told my son that when I took it in for the first oil change I would have the dealer check it out.
I decided to look on the internet to see if anyone else had the problem. Well, it looks like quite a few people have this problem. Some suggested following the instructions in the owner's manual. Tried that without too much success. A few people mentioned installing two washers under each screw to bring out the bracket. I felt that the bracket was not out far enough to engage the latch. So I gave it a try. It worked.
Ford Maverick Rear Seat Not Latching 1651076560246
With washers
Ford Maverick Rear Seat Not Latching 1651076543664
Without washers
Ford Maverick Rear Seat Not Latching 1651076477434
Without washers
I hope this helps fix your problems
LeersMav
Maximus GP
Orange County, CA
So if you slammed it really hard without the washers would it latch?
Also is there adjustment seat side.
Yes. I have a pet hammock and use the child seat tethers to secure the straps.
I always slam it to secure the latch whenever I remove or reinstall the hammock. I'm okay with that.
Ford Maverick Rear Seat Not Latching RearSeatBackProtector
landscpdesgnr
liz
Orlando FL
Ford 2022 Mav XLT Lux CP360 & Ford Fusion 2014
Same thing happened to us, I couldn't get the seat to latch after bringing it home and inspecting. I was afraid to slam it, it is husband's truck lol, so he did, it worked.
BretMaverick
BretMaverick
Stan
Albany NY
Slamming it really hard did not latch in my case. Some people had success with slamming it hard. If you can not get it to latch by hard slamming, give the washers a try. It's an easy fix, minimum cost and time. Does require a #30 Torq to remove the screws.
WannaMav
Hawaii
2022 Maverick hybrid
Have found (at least on my Mav) that pulling on the releasing strap - the same way one does when unlatching - while putting the seat panel back up and then releasing the strap once it is fully shut rather than just slamming it closed does the trick.
Egz
Fredericksburg, VA
2022 Maverick Hybrid Lariat, 1967 Fairlady
I had to slam it to get it to latch. I was suspecting it was the first aid kit I put back there was sticking out just enough to put pressure on it from latching softly. Maybe it always that way.
Zackmix2020
Zack
Los Angeles
2022 ford maverick 2.0
Same thing has happened to me, I would slam it as hard as I can but nothing worked. It eventually fixed by itself but this was helpful if this happens to me again.
Ford Motor Company
Official Ford Account
Dearborn, mi
With washers
Without washers
Without washers
Hi there! Send a private message to us with your VIN and the name & location of your Ford dealership, along with some more details about your situation. I’ll look into this for you. Thanks!
bgn
WA
Same issue I had. "Fixed" it by placing my palm on the front of the seat where the it lines up with the latch on the back and slammed it will follow through.
Works fine for me now.
Kirkstone
W. Central New Hampshire
Maverick, BMW X1, MINI
Mine was delivered with the rear seat back unlatched :rolleyes: but finally a hard enough slam got it sorted. On the punch list.
nunucello
Marcello
New York
With washers
Without washers
Without washers
Have you tried this :
1. When the seat is down pull the release handle.
2. Start to pull up seat
3. Hold seat with other hand and let go of the release handle
4. Finish pulling up seat and it should latch
The trick is that the seat will not latch if the release pull is still extended out.
Hope this helps.
troynm
New Mexico
2022 Maverick Lariat hybrid, Velocity Blue
I have the same problem so I'll try to sort it out tomorrow. I've tried pulling on the latch while I close it and generally have to just slam it really hard.
