Rynobuilt
swmo
2025 lobo
I installed a Prinsu roof rack on my 25 lobo, I'm loving the looks, kind of blending 2 styles together!
you do have to drill 4 holes in the roof, and its not suer easy, but after struggling with the front driver side, I think there is more structure there , or its hardened beam the other 3 where much easier.
I used a 7/16" hole saw to start the first opening hole up, then follow top with a rotabroach type spot weld drill but to get through the remaining metal pieces. there is many layers at the spot on the roof cap. After that use the 7/16" hole saw again to get the lower roof rail trim pieces cleared out, then add some paint to protect it, install the supplied plus nuts, rtv sealant and install.
I had mine color matched and powder coated with color from prismatic colors that is very close to the factory match . With a 400 dynamic weight load and 800 static load rating , these are super strong and can hold about anything these little trucks can haul around!
Ford Maverick Prinsu roof rack installed! IMG_1964
https://prinsu.com/product/ford-mav...XIvRXKuJMsSTHnls7WO-iHJVUA218lvllSLESGiT63neS
Ford Maverick Prinsu roof rack installed! IMG_1950
Ford Maverick Prinsu roof rack installed! IMG_1952
Ford Maverick Prinsu roof rack installed! IMG_1951
Ford Maverick Prinsu roof rack installed! IMG_1953
Ford Maverick Prinsu roof rack installed! IMG_1954
Ford Maverick Prinsu roof rack installed! IMG_1957
Ford Maverick Prinsu roof rack installed! IMG_1959
Ford Maverick Prinsu roof rack installed! IMG_1962
Frenchy
Bert
Taylorsville Utah
I like the look but it seems to be a work of work to install and it cannot be removed. What are you going to use it for? How does it looks inside?
Rynobuilt
swmo
2025 lobo
its not bad with the correct tools, you can remove it any time, just get some grommets to install into the holes, its only 4 1/4" threaded holes.
ill use it for my paddle boards, snowboards, and maybe roof top tent
commadorebob
Looks good, but I agree with the above sentiment on drilling holes in my Maverick.
Quick serious question, why did you opt for a roof rack rather than a bed rack?
Cancunbadlands
Cancun
Cancun
Water intrusion?
Bob Hamilton
Vancouver, Canada
2025 Maverick Lariat Hybrid
It takes a brave man to drill holes like that LOL
twntyfive2life
MN
2025 AWD Hybrid XLT 4K Lux
I don't expect my Maverick to last as long as my old 4Runner but that thing had a roof rack hole rust out. I'd make sure all bare metal is painted and primed and I'd also put a bit of fluid film or something in the holes. I'll figure out a different style rack for the Maverick.
wax87
Stuart
Dallas South
2004 Avalon
I might even consider some type of dubbler under the sheet metal. Just to stiffen it up if nothing else.
Mavreezy
Peter
Long Beach, CA
The roof rack looks good on your truck. Nice job 👍🏼
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
Love both the look and the utility of the rack.
Ford Maverick Prinsu roof rack installed! 1771269326763-tc
jgrcubed
Atlantic City NJ
Maverick Lariat
Cation
The fact that there was so much metal combining at that location, sounds structural. The rack looks good and sturdy. The roof, maybe not so much...now.
Mudduck
JD
Utah
Prinsu makes awesome racks! I have one on my Forester as well. Drilling holes is never fun, but the end product looks great and they are super strong.
Great install OP, its a nice look IMO.
Bob The Builder
Butch
Vermont
Looks great, kudos on a nice install. I can see you measured 3 times and drilled once. :crackup: Man, that project is NOT for the faint of heart. It takes brass nards to drill those holes.
