Passenger side wiper blade
stevhorn
Nowhere
None
I noticed that the passenger side wiper blade presses into the plasticy, rubbery trim piece at the bottom of the windshield. It actually bows the wiper blade a little bit. Does anyone else notice this on their Maverick? The design is similar on my Bronco Sport but it does do this on it.
Here's the Maverick:
Ford Maverick Passenger side wiper blade IMG_20220513_192647972
And here's the Bronco Sport:
Ford Maverick Passenger side wiper blade IMG_20220513_192633357_HDR
bradFORD
Springfield, MO
Ford Ranger
My First Edition Hybrid wipers don't go down that far but I thought they should for air dynamics
Bad Actor
Christopher
SE Missouri
01 Ranger XLT, 73 Mustang Base, 02 Toyota Camry
Might check and see if that wiper was put on correctly or the passenger/driver side wipers were swapped. Driver side is 22 inches and passenger side is 21 inches in length.
999
Boxster, Yamaha FJ1300, Maverick XL
Class Action Lawsuit??
AnthonyMav
Anthony
New Jersey
Maverick XL Hybrid
You can move it up and down. I noticed when I washed the truck that it can be repositioned by hand up or down an inch. Try putting it back where it’s supposed to be and see if it stays after using the wipers.
LeersMav
Maximus GP
Orange County, CA
Just did a front windshield glass chip repair 3"s above the right wiper. Did not notice it touching or bowing.
BUT, when I moved the wipers manually so I could repair, as SOON as I turned on the ignition, the wipers repositioned and no touching or bowing.
ehauser
Eddie
Nashville, TN
2015 Mazda 3, 2022 Ford Maverick Hybrid
I just washed my windshield for the first time. Only had it for a week and I noticed the wipers stuck up past the black area after my first use. I wonder if this is an issue as there seems like a lot of play and I can push them down to the correct position. But as soon as I use them they are stuck above the black area again.
LeersMav
Maximus GP
Orange County, CA
Maybe an adjustment on the wipers themselves.
Just looked at mine. The right side is just above the black while the driver side is about 1-1.5" into the black.
Visit to the dealer? Not sure. Maybe ask FMC.
Geep
Paul
SK Canada
2022 Ford Maverick XLT luxury hybrid
Just back from the dealer after first oil change. Complained about wipers not parking low enough, they said thats normal????? bull crap IMO
Ford Maverick Passenger side wiper blade 8B823219-F2DE-45B0-9E45-1469A6F3BEEF
Maverickent
Kent
Mason City, IA
I have the same issue. I was very annoyed with it, because it prevents the wipers from coming to rest all the way down when turned off. It's an obvious design flaw. My way of 'fixing' it was to replace the passenger side blade with one that is an inch shorter than the original. It still contacts that seal, but it allows it to go down a little farther when off.
It should be stopping on the circle in a circle that you see slightly above it. That's the marking for alignment.
Although with the wiper linkage assembly being movable when unpowered it sometimes doesn't take much to shove them down. I noticed with our lovely blizzards here of late the snow can push them down to getting wedged into the rubber piece.
Uncle Ed
Georgia
1968 Camaro, 2017 Toyota Highlander, 2024 Maverick hybrid
Just noticed mine this week , passenger side wiper not parking low enough, moves by hand to better position. Anybody actually get it fixed?
ReadyMav
Peoria, IL
Honda Accord
For what it’s worth…mine does the same thing and I was told it was normal as well. I don’t get it either. Be prepared for other head scratching things with your Maverick…ie. Check your center console. Mine came with felt on it from the factory to keep to quiet.
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
Mine was parking too high up. I removed the wiper arm and moved it downward a bit and now it parks perfectly. It was bugging me because from inside I could see the wiper when turned off, now it's "hidden".
Note: I removed the arm (with the hood open). I had to use a wiper arm removal tool as I could not get it free without the tool, even with some prying against a wood block.
mwillfly
Saint Charles Missouri
First Edition Rapid Red AWD
My passenger wiper blade is like that too. Only issue I have . thought maybe the wiper was to long . I’m having the dealer look at them when I change my oil
