Automan21
Mel
CT
‘23 XLT Eco AWD 4K Tow
Cornering especially. Even sport mode sometimes doesn't quite hold a gear when you're light on the throttle as you set up to exit a corner. It ends up shifting up and I'd love to keep it in gear throughout the turn.
Even in non spirited driving, I'll be able to granny shift and instantly select a gear if I need to pass or merge, and then shift up to cruise without having to change drive modes. Ive been driving in sport mode exclusively since I got the truck.
This is the first automatic vehicle I've owned and I was very accustomed to being in a specific gear while driving.
Thats exactly what I want! All my cars for the past 25 years have been manual 5 or 6 speed.
MankDeems
Zac
Fargo ND
99 ranger 4X4 XLT, 04 Mazda6, 17 ninja300
All of us begging for the RS transmission to be fitted to a maverick but nobody's listening...
Ford Maverick Paddle Shifters install on Maverick XL -- DIY install instructions, photos & video 43178d1b003a8b0dc49d106c6186ae32
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
It would be cool but theres a lot of modules on this trucks that would need to be mess with if the transmission its removed. Im down for that RS conversion too.
Maverickman74
Shane
Maui HI
WOW! Your idea of a DIY installation is advanced engineering to me, especially when it comes to electronics.
Being a 68yo I was raised on points & plugs, condensers, distributor caps, lights and a radio being a vehicle's electronics, but I appreciate the effort and ingenuity of you folks enhancing a modern vehicle.
Man...am I old! 🤔 :eek:
No kidding. Two months ago I wired upand plumbed a external fuel pump and auxillary control panel on my Comanche, and today I replaced a broken steering box and upgraded to a long travel track bar and steering setup that had to be modified a couple ways to fit. All that was easy, but this has got me head scratching. I think its just a fear of changing wiring on a vehicle with soooo much wiring lol.
Way to go OP! One day I may work this out, the one thing the Maverick is totally missing is manual shift control.
2023Area51
Midwest
2023 Maverick XLT Hybrid
This is awesome! Thanks for such a great write-up!
TacoTanium
Earth
XLT
When my kids grow up (10 years later maybe) and I start to have more free time, I may have to come back here with 50+ questions, lol. Assuming I still have a maverick by then.
Do you have any feedback on what gear your in?
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
When i install the digital cluster i will be able to know what gear im in . With the xl cluster you cant see the gears that you are in .
jdmancus
North East Pennsylvania
Ford Maverick LARIAT AWD, 97 Toyota 4 Runner
Parts list of things needed for the conversion will add them here later on.
Steering control Module from Ford Maverick XLT With Heated Steering Wheel and lane departure if you want it. Module will Come with both switches and Clockspring.
Steering Wheel that comes with Paddle Shifters of your preference Ford Escape Or Bronco. i took a risk and bought an European on From Ford Fiesta ST but you dont have to spend that money for it.
PCM Wiring terminals X3 so You can add them to the pcm connector.
DU2Z-14474-CA
Steering control module
Connector Terminals X3
DU2Z- 14474-BA
Wires Looms , Zip ties and shrink tubing for wiring and 3 different colors 16 gauge cables.
Ok here we go with the wiring . Corsair clock spring connector .
Transmission paddle shifters wires diagram. adding here.
Now i will be adding the Ford Maverick 2022 XL since thats the one i drive . Mine already has Cruse Control added and other switches. Notice this one on the PCM Shows it already comes with 2 wires for the up shift and down shift on XL model its false the diagram i had to add all 3 wires.
PCM Connector from 2022 Ford Maverick shows pin 5 and pin 6 from pcm having shifter up and down . Good sign """
Connector from clock spring to steering wheel shows pins could be added for the steering wheel .
Im adding this because this its the steering wheel i bought. from UK ford Fiesta
Now i will add process . and pictures Start By removing Negative Battery Terminal.
And remove Air bag From steering wheel.
you got to do both sides. once you removed be carful disconnecting the 2 air bags to clockspring connectors . use a pocket screw driver or Pick . just carefully pull clip and press on the sides with your fingers and pull up. first your going to disconnect the white connector of the horn.
once you remove the air bag you should put the wheel straight, remove clockspring connector on top and remove the 24mm bolt so you can remove steering wheel from the steering column.
Once you remove the steering wheel you should left like this.
Remove bezel from steering Column 2 bolts on the bottom. be gentle with this as this interiors on the mavericks gets scratch easily you know the drill with mavericks interiors.
Unplug all connectors on Steering Control Module and remove the steering control module 4 bolts you will see they are big black bolts torques t30 or t27 dont remember right now lol apologies. when pulling out be carefully as on the back they have notches that holds it in place.
Once you removed it install the new one that you bought for the conversion and follow the same order but before you install the bezel install the 3 pins and make the wire harness for paddle shifters.
part numbers for connector and wiring its on top.
thats how it should look like when install with ford oem terminals .
PIN 5 = upshift / PIN 6 = Down shift / PIN 7 = Signal Return needed """
Make A Hole on the rubber by the firewall your going to see a big plugged and pass the wires true it make sure to but insulation on the wires to protect from ambient and rotten.
dont know if you can see the wireloom pass true and the harness i made.
I pull the wires next to the battery and used the whole true to pass the harness to the fender well area . clean and secure cant even find it in the picture. lol
Remove front Driver side wheel and fender liner. and remove PCM dust cover to get access to connector.
remove first pcm connector the first one to the right. remove the tape cut a little bit of the insulation from factory . With care always. remove the top of the connector shield and bottom white pin protector all with care. maximun care when removing or installing terminals. as you can see i added the 3 cables alreay on the connector was kind of on a rush.
heres wiring on terminals your adding to this connector mine did not come with them but on the ford wiring it says some come with up shift and downshift terminals already on the connector be aware.
heres my little hand writing explaining the wire harness i made and the part number for the pcm terminals that will be needed.
Install everything back toghether the same way you took it out. Next i will post Instructions for enabling with forscan. be patient with me.
heres clip of the car running already and test driving the paddle shifter.
YOU ARE THE MAN...PLAIN AND SIMPLE!!!!
RLmesc
Randy
Dubuque, Ia
18 Kia Sportage, 05 Porsche Boxster S, 85 Kawasaki
I miss my tiptronic shifter in the Kia but love the Mav all the same. With paddle shifters or tiptronic, this truck would be perfect. Make it upgradable for us without but who want in on it.
I use the "L" button, but it is still iffy when trying to corner. While we are at it... lose the damn electric pkg brk and give me an lever parking brake to drift in the corners during snowfalls... then perfection has been obtained.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Im just happy i can help you guys get the most of your vehicles for free i dont gain nothing from this . i get a lot of hate for it but its ok. this might be not use full for some but for me its was just kind of fun having it on my cheap XL . I try my best to help but my English's not so perfect but all im trying to do its guide the ppl on the process and pray for the best that you will understand. any question feel free to ask. thanks for the ppl that gave me support i appreciated it.
