On Board Tire Pressure Reading
Douger
Doug
el cajon
2015 Fusion Hybrid
My Mav has been wandering a bit lately.
I checked the on board pressure which read 31 psi all around. I inflated to the recommend 35 psi using a trusty guage of my own. The Mav display now shows 42 psi.🤔 Has anyone else found that the on board display is not accurate, any way to calibrate it if so?
Thank you!
Ozarkbeard
I've had the truck onscreen TPMS read different pressures on two consecutive days, when my manual gauges didn't change more than a pound.
Not sure if the onscreen TPMS reading is very accurate or not. It is very handy though, to give a ballpark pressure reading. If one tire consecutively shows much lower than the others, I check the TP.
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
Hmmm🤔
I'm trying a few different guages now to see what's up, I guess we'll see in time.
I hope it's not a matter of resetting the TPMS occasionally!
Hot Runr Guy
West Chicago, IL
Thank you!
Are you checking stone cold, or after driving a bit? I easily see a 5-6psi difference between 25/30F and 70/80F. My dash display is right on the money compared to multiple other gauges.
HRG
TIRE PRESSURE MONITORING SYSTEM PRECAUTIONS
Ford Maverick On Board Tire Pressure Reading {filename}
WARNING: The tire pressure monitoring system is not a substitute for manually checking tire pressures. You should periodically check tire pressures using a pressure gauge. Failure to correctly maintain tire pressures could increase the risk of tire failure, loss of control, vehicle rollover and personal injury.
WARNING: Do not use the tire pressure displayed in the information display as a tire pressure gauge. Failure to follow this instruction could result in personal injury or death.
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
It's cold, has been sitting for a day.
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
Good post HeyBales,
Makes one wonder. 🤔
Guess I'll try multiple guages 🙃😳
Prickly Pear
Pacific Northwest
24 Maverick XLT CG, 92 Ranger
Picked my truck up from the dealer three days ago. Checked the TPM today and it said 40,40,40,39. Will try to check tomorrow with several gages to see if there is any agreement.
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
Guess we'll see🙄🤔
inline_five
2023 Hybrid XLT
Douger
Douger
Doug
el cajon
2015 Fusion Hybrid
Thank you Inline, I'll check it out!
kjb13
Kevin
Lancaster, PA
2010 F150, 1972 VW Bug
They ship them with higher pressure.
TKranbuhl
2024 Ford Maverick
I use the AstroAI Digital, also. It matches up with on screen psi. Just make sure you are on the PSI scale. There are 4 different settings.
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Its the Computer..
I have been running on Factory Connie's for six months now. (these were take-offs from another Maverick, Steelies too). That did not come with TPMS's.
I get a tire pressure warning, after driving for 25+ miles.. An than every 10 or so, after that.
When, I get back to my garage. The truck senses My Original set, stacked up about five feet away and is content again..😉
Two days ago, it was telling me my Left Front was only at 27 psi.. 😄
I DO Check my tires very often (visually and when anything feels wonky) and do a PSI check, once a month.. I come from a family of auto mechanics...
So Far, So Good.. 😎
Jerry
