- May 29, 2024
- Central Nevada & Utah
- Maverick XLT Hybrid
- Engine
- 2.5L Hybrid
A good case for buying extended warranty?
Hope it goes smoothly and doesn't cost a fortune!Blackstone reports were very clear.
The engine oil was perfect. Transmission had 1089 ppm iron vs an expected average of 53. Nickel and Boron were slightly high as well. The additive package of the oil still looked good so this failure is not due to old/bad lubricant.
Started the process of removing the transmission today. Hope to have it out before the weekend is up.
Did you happen to measure the fluid volume of the old transmission fluid that came out? Had it been properly filled?Blackstone reports were very clear.
That right there folks is why I droppedGot word back from the dealer:
Recommended service
$399.90
Other | trans diag/info: verified concern, performed eec test retrieved multiple codes in pcm and sobdmc for internal clutch A fault issues and Generator Torque Delivered Performance and Transmission Range Sensor Alignment, also retrieved code p1061 Excessive Engine Component Deterioration, they have a tsb for this one to reprogram 4 diff modules,....
So they are saying the P1061 is in error and only requires reprogramming. But……
$7,716.20
Other | need complete transmission assembly
failed transmission that requires complete replacement. Seems super expensive. Will probably have a second opinion before dropping 8k.
Here you go. Very similar to the HF35 from the Fusion.
The large gear in the middle is the top gear on the transfer shaft. The shaft consist of three gears and ties all of the inputs/outputs together.
The shaft at the top of the photo is the input from the electric drive motor. It connects to the top gear on the transfer shaft.
The large gear on the bottom left is the differential that send power to the wheels. It connects to the bottom gear of the transfer shaft.
The smaller gear on the bottom right is the gas engine input, parking mechanism, as well as the starter motor. It connects to the middle gear on the transfer shaft. This is where my issue lies. The middle gear on the transfer shaft is spinning freely (loudly). Not sure if it is splined to the shaft or just press fit, but either way it's not any longer. This explains why I was able to move the truck under electric power, but all hell would break loose as soon as the gas engine would start to drive the truck. Oddly enough none of the gears show any wear or damage.
I'm in the process of double checking all of the bearings. Pulled the sun/plant gears out yesterday and they look fine. This necessated the removal of the starter motor. Those permanent magnets are strong! Ended up pulling the stator first as I could get my hand under it for leverage, but I missed removal of one wire broke it. Haven't flipped the transmission back over to see if it is an easy fix.
I would check on line, or ebay for a complete engine, and transmission from a wrecked Maverick, then pay over 7K from a dealer to repair what is wrong. Now you can find just about any Maverick item you need if you look.Here you go. Very similar to the HF35 from the Fusion.
Or do what I did as stated in post # 21 and sleep soundly, :’PI would check on line, or ebay for a complete engine, and transmission from a wrecked Maverick, then pay over 7K from a dealer to repair what is wrong. Now you can find just about any Maverick item you need if you look.
Thanks for the Picture very helpful for the Hybrid Owners.Here you go. Very similar to the HF35 from the Fusion.
Awesome post! Hope the parts are available and it works out.Don't worry. Not dropping a dime at that dealer. Might reach out to Ford to see if they will comp me some parts.
Figured out the easy way to remove the electric motors. A 3" deck screw head and shaft fit perfectly in the slots of the motor. Screwed them in to a short section of 2x4 and pulled it right out. No special tool needed.
Link above shows the gear/shaft issue.
I hope you will dissect the failed gear and let us know how it failed and how it is constructed. Thanks for sharing this information!LX6Z-7H348-B - $707.31 from the dealer. Should arrive later this week.
