I know I need more than 3 minutes to defrost with Maine winters no matter the car lol. I'm not driving without clear windows.Worst idea ever.
Since you have hot air in these in 3 minutes. If not, have yours checked out.
No not always.Does the hybrid ICE always get up to full temperture?
It is a great question. Your last sentence says it all, because oil circulation is not the issue. No one has mentioned metal contraction as it gets colder thus creating a bigger gap in bearing tolerance. More gap, more chances for wear. It's best to let the engine warm up in cold weather before its put under a load in my opinion.Great question. I been wondering the same thing, cause if you drive on electric for a ways and then the gas engine starts it seems like the gas engine is running at a higher rpm then normal. But if i start the gas engine right away in the garage by pushing gas pedal to floor before leaving it seems like the gas engine doesnt run near as hi rpms. I would think stating the gas earlier would be easier on the engine.
Mine is an XLT Lux, but as far as I know the seats and steering wheel start in the same condition they where in when you parked it with one exception. If the seats were on the '1' or '2' setting they will automatically go to '3' the next time you start it. If seat and/or steering wheel heat was off when you parked it, they will be off for the next start. I have not played with the app much, but it would be nice if you could set a default start up condition for the seats and wheel or even have several options based on outside air or cabin temp. Maybe the app does have the ability to do this, but I haven't seen it.In the lariat trim, does the steering wheel and seats warm up when you start it in the winter? Never had anything that fancy so i don't know. I only have the XL
If you don't press hard on the gas pedal, it has a built-in gentle warmup cycle. Pressing hard, like to accelerate quickly to highway speeds overrides this. At 40°F everything is warm (over 122°F) in 3-4 minutes. Catalytic converter is 1000°F in 2-3 minutes.It is a great question. Your last sentence says it all, because oil circulation is not the issue. No one has mentioned metal contraction as it gets colder thus creating a bigger gap in bearing tolerance. More gap, more chances for wear. It's best to let the engine warm up in cold weather before its put under a load in my opinion.
Warm air in 3 minutes, sure.
Melting a thick layer of ice will take longer. But they also have these:
I hear ya.there's that lol. I can't scrape fog off the windows though lol. Those stupid glazes of ice will fog the hell out of the inside of the windows. Generally by the time the scraping and brushing is done, the windows should be almost clear. Wish I couldve gotten rear defrost on my XL.
My kids would roll their eyes and call me “old man”..In a normal car, you start the motor and let it run to allow the oil and lubicants to flow around the engine before getting under way. At least I do, especially on cold mornings. The hybrid however doesn't start until it is needed. When I first take off it's on battery only and then the motor kicks in.
Is it a problem for the motor to start under load without first circulating the oil and such?
If this is an earlier thread I couldn't find it.
My first car was a 1973 Ford Maverick with the 200 ci straight 6. I would never have considered getting under way until the car stopped idling high and settled in. I guess that's not something to worry about any more. Old habits are hard to break.My kids would roll their eyes and call me “old man”..
It took me a long time to stop pumping the throttle pedal once to set the choke and squirt gas into the carburetor. Old habits are hard to break.My first car was a 1973 Ford Maverick with the 200 ci straight 6. I would never have considered getting under way until the car stopped idling high and settled in. I guess that's not something to worry about any more. Old habits are hard to break.
