MoonMan's build log
MoonMan
Jesse
Virginia Beach
2023 Maverick XL | 2019 Jeep Cherokee
I'm going to track and share my progress here for my planned projects for my 2023 XL Hybrid in Cactus Green in case anyone finds it useful.
Ford Maverick MoonMan's build log 1691592517806
  • I followed this guide, but ended up using some differnt products. The guide was perfect, though, as long as you use parts that work, and it was pretty easy to accomplish. I ended up using the following products:
    Wireless charger
    Power Supply
    Fuse Taps
    I tried using the wireless charger suggested in the video guide above, but the one the vendor sent me was not the one in the video or the one pictured in the Amazon listing. It ended up not being compatible with the power delivery from the power supply (even though on spec it should have been). I ended up going with the charger linked above and it works great. Right now, I'm using the included magnetic ring mount, but it doesn't hang on in tight turns, so I'll be swapping out the metal ring for 3M Gorilla Glue strips.
    Ford Maverick MoonMan's build log 1695040359898
    Ford Maverick MoonMan's build log 1695040383757
    Ford Maverick MoonMan's build log 1695040408557
    Ford Maverick MoonMan's build log 1695040450869
  • splice in a USB hub behind the USB panel so that I can hardwire my AAWireless module
  • add some chonky Falkens
  • I used a brand called Patriot Liner installed by a local shop. Very happy with the result for $500.
    Ford Maverick MoonMan's build log 1691588030259
    Ford Maverick MoonMan's build log 1691588054100
  • dress up the steelies (maybe)
  • lift the front to match the rear height
  • I went with this tonneau cover from Rough Country and so far I'm very happy with it. Install was decently easy, except I didn't end up needing the 6 rubber pads that were intended to act as spacers/support between the cap over the side of the bed, and the bed itself. Installing them as indicated caused the rails to misalign. Could be because I have a spray-in bed liner.
    Ford Maverick MoonMan's build log 1695039673254
    Ford Maverick MoonMan's build log 1695039697136
    Ford Maverick MoonMan's build log 1695039724823
    Ford Maverick MoonMan's build log 1695039746416
  • hide my garage door opener somewhere in the ceiling
  • I cashed in FordPass points for the letters.
    Ford Maverick MoonMan's build log 1691588250849
    Ford Maverick MoonMan's build log 1691588274079
  • I cashed in FordPass points for the tailgate assist.
    Ford Maverick MoonMan's build log 20230811_082326
  • I used a bracket from Sly Brackets, a company I discovered when I needed the same thing for my Jeep Cherokee ~5 years ago. I was super happy with the result then, as I am now with my Maverick's bracket.
    Ford Maverick MoonMan's build log 1691588374447
    Ford Maverick MoonMan's build log 1691588471232
    Ford Maverick MoonMan's build log 1695039275003
    Ford Maverick MoonMan's build log 1695039312884
  • add power tailgate lock (guide)
  • add some sort of LED DRL (probably a light bar style; open to suggestions)
MoonMan
MoonMan
Jesse
Virginia Beach
Changelog for main post
  • 08/09/2023 Original post: completed black lettering, bed liner, and front license plate bracket.
  • 08/09/2023 Added header image.
  • 08/12/2023 Updated status for tailgate assist.
  • 09/12/2023 Added power tailgate lock and LED DRL items to list; added links to guides and products.
  • 09/18/2023 Updated status for wireless charger and tonneau. Add additional pictures for the license plate mount.
  • 09/18/2023 Changed adhesive strip for wireless charger from 3M to Gorilla Glue strips.
lajlmt
Lance
Rio Rancho
‘23 Maverick XLT LUX
  • add a wireless charger
  • add a tonneau cover
  • I used a bracket from Sly Brackets, a company I discovered when I needed the same thing for my Jeep Cherokee ~5 years ago. I was super-happy with the result then, as I am now with my Maverick's bracket.
Where did you get the front plate holder? I have looked everywhere! Pic pls.
MoonMan
MoonMan
Jesse
Virginia Beach
Check the spoiler button for a link to exactly where I bought it. I'll get another, more detailed picture of the bracket posted soon. I've used SlyBrackets.com twice now. I've had one on my Cherokee for 5 years with no issues. Super helpful and responsive company, too.
EchoPear
Nathanael
Indiana
‘24 XLT Hyb/HPR/Lux/360/Bed Rail/Moonroof on order
This is a cool way to format the build process instead of like others doing a million page thread
MoonMan
MoonMan
Jesse
Virginia Beach
Thanks! I tried be thoughtful about it. Only problem with this approach is it doesn't get pushed to the top when I update existing posts.
lajlmt
Lance
Rio Rancho
Thanks!!
Montauk
Brit
2024 Maverick XL, 2023 F-150 Rattler pkg
Thanks for creating this post. I’m expecting nearly the same truck and I’m enjoying seeing what you do to it.
@coyotewr.x painted his wheels with Steel-x and they look great. Aside from spending the $ on take-offs this seems to be my favorite option so far. Keeping with the Cactus Gray& Matt black theme looks pretty good.
Ford Maverick MoonMan's build log 1693662546542
MoonMan
MoonMan
Jesse
Virginia Beach
Happy to share! Dude, those chonks look sick with the black steelies. Thanks for confirming that it looks good :cool:
Montauk
Brit
How about an update...
Montauk
Brit
Fog light bracketry: LINK
Definitely on my list. Mine is set to be built the week of 2/19
