Maverick Windshield Washer Pump Failure
acaron47
Allen
Daytona Beach, FL 32124
2022 Ford Maverick Lariat Hybrid
My 2022 Maverick Lariat windshield washer pump will only spurt out just a spit of water. This is the second time this has happened in two months. The Ford dealership found a clogged pump inlet and squared that away and now the pump buzzes or hums but no water is sprayed on the windshield. And the pump reservoir tank is a pain to access. Now I have to replace the pump. Is there a history of washer pumps failing?
A few of the 5 similar threads now shown below your thread sound like prior issues. But not that many like a huge issue.
I'm expecting problems earlier than others as I barely use it.
bgn
WA
Doubt it's the pump. Likely the windshield washer fluid you use gunked up the hoses. I believe the bug remover ones are more susceptible. I'd clean those out first.
Marty
2026 Ford Maverick Tremor
I run a 50/50 mix of rainX and water. My water is very pure, I don’t foresee any problems.
In the winter I run the -20 degree stuff at full strength.
acaron47
Allen
I figured the pump was good because I can hear it buzz when I hit the washer lever so I looked up how to access the reservoir. The procedure on line makes it sound so easy but after trying to even see with the wheel well liner removed I can see why its the weakest link. That reservoir and all the connections are buried in the fender. So I called the dealership and the maintenance guy tells me it won’t be until late September before he can get me in and finishes by saying, and I quote, “and I’ll need the truck for two days to fix it.” I’m a retired aircraft A&P technician and I said BS. Forget it, I’ll do it myself. So I’ll be out there, weather permitting to do his two day job in about four hours.
Now that my rant is over, what is best to clean the reservoir?
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
Check all of the physical hose connections, is something disconnected or leaking?
Cancunbadlands
Cancun
Cancun
It's been reported before at the Bronco Sport Forum
Ryom
PA
2025 Lariat 4K BAP Eruption Green
I'm putting clear fluid in mine on the theory that the cheapo blue dye stuff that stains and coats everything else does the same to the tubing and pumps. Presumably you could make your own fluid with distilled water and alcohol, but I like the rain repellent stuff so I just buy the clear Adam's fluid.
https://adamspolishes.com/products/adams-all-season-windshield-washer-fluid
dldjtad
Bartow, FL
2023 Ford Maverick
I believe that the types with the bug wash in them cause the problem. Just to be safe, I use straight water.
scotty
pompano berach fl
dodge caravan
right. that what I was thinking about an hour ago. maybe add bit of rugging alcohol.
Just maybe distilled water, less calcium, maybe. but thanks a bunch for your considerations.
guy i talked to yesterday. paid 500 bucks at dealer to unclog his reservoir bottle. man this is big expense. dealer told him he should have used 2/3 s water and 1/3 solution. I think just water as u said and some alcohol.
dldjtad
Bartow, FL
2023 Ford Maverick
Wow, they charged me only $100.00!!!
Carlitos_92
I have been using the cheap Walmart brand for at least 20 years, in a half-dozen vehicles, and have never had a single problem...
Ford Maverick Maverick Windshield Washer Pump Failure 1760804939247-8u
scotty
pompano berach fl
dodge caravan
Maybe other cars, but my friend with the maverick had his clogged. it is a 24 maverick.
Dealer said the reservoir has a lot of screws and bolts to get access to the reservoir. I'm 71 a lot of cars and vans over the years. Not one of mine clogged up before, but hearing maverick owners complain.
