Maverick Hybrid as Booster Vehicle?
Tbone289
MO
Funny thing is. Last night when I posted that I remember saying superconductor instead of super capacitor🤷‍♂️
You remembered correctly. They are supercapacitor jump starters, not superconductor as you posted last night.
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
Who can explain why the battery charger works attached to vehicle but the jump pack won't?
If you're using a lithium jump pack, my best guess is that the BMS software wasn't designed with that use case in mind, so it errored out when it detected something outside of its programmed range. This is when a lithium jump pack with a force-start/boost or other mode that disables all the safety features is helpful.
You could try an old-school gel cell jump starter like the Jump N Carry and see what happens or doesn't happen. If you already tried that and got the same result...no idea then.
Mavster Mechanic
Hybrid
Yes, you nailed it.
I forgot the Golf Cart LiFePo batteries go "open circuit" if they get too low. And like too low is 11 volts Kinda sucks they shut off vs. fade away.
OTOH I still can't explain why it wasn't "open circuit" after I detached one lead from the vehicle. Just weird to me.
Also my cheap end jump pack does have a override feature that I didn't know about. I will try again if opportunity presents.
Sometimes "smart" features don't help you!
Yes, you nailed it.
Some are programmed to check for 6, 8, 12 volt batteries. So if you have a 12v below 7 volts you will need to select 6 volts on charger (if it doesn't have force mode) and charge long enough to get enough to use 12v setting. The battery will still need 1.5-2v to recognize a 6v battery to charge. OR hook an additional 12v battery (+to+/-to-) to the dead battery and put charger on that battery charging both batteries at same time. (Old timers force mode 🤫😇).
notfast
Los Angeles CA
Which one do you have? I wish more companies would list force-start/boost as a feature instead of having to read the owner's manual. I currently have the YaberAuto "8000A", which has a force-start mode, a semi-decent air inflator, and a screen big enough to easily read through the gap in the hood while sitting in the driver's seat. It's just a little on the bulky side. Frequently goes on sale for $80-90.
https://www.amazon.com/dp/B0D41NT5KL/?th=1
Flyangler
Sarah
Minnesota
2022 Ford Maverick Hybrid XL
Ok, now that you have gotten good and helpful answers, I will tell you my reaction when I saw the title of the post: Is the Maverick acting as a booster seat for for another car to sit up at the dinner table?
Carry on!
MattTX
2024 Maverick Hybrid XLT
Whatever jump pack you get make sure it has a good boost feature. I have a Gooloo (https://www.amazon.com/dp/B0FNMLG15N?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1) and it works great, I've had a dead battery 3 times in the past couple of months and without the boost feature I wouldn't have been able to start my truck. I have a 2024 hybrid (that I bought new in May 2025) and it's time to the go to the dealership for a warranty replacement. Wheee.
I haven't used the air pump and I know that's always a weaker feature on these things but figured it was worth having in case of an emergency, or if I just need to inflate a ball or tube.
Edit to add: my only minor complaint with the Gooloo is the jumper cable part is short and barely reaches between the positive and negative points under the hood.
inline_five
2023 Hybrid XLT
Maggie5618
Maggie
Southern California
2025 Maverick Hybrid XLT AWD, 2018 Civic-manual, 2001 S2000, stock
Carry on!
Maggie5618
Maggie
Southern California
I left my Schumacher jump/air compressor out in the rain, and bought a Wolfbox 4000 to take it's place. I like it, except I have to hit the boost button to jump my mower. Good idea to keep one in every vehicle and keep it charged.
I agree that each vehicle should have a jump box. A 4000A would let me charge my Maverick's big brother, F350, (jump start up to 10L engines, gas or diesel). 😁
Maggie5618
Maggie
Southern California
🤔 If you have a super capacitor everything will appear to be a superconductor!!!!
All this reminds me of Back to the Future and a Flux Capacitor. Then I could go back in time and remember to turn off the Civic's accessory mode and still have a charged battery. BTW, Amazon realized that I was looking for super capacitor when I cut and pasted in superconductor. :sunglasses:
