Maverick Gas
tciotti2003
Tony
Arizona
2022 Lariat
So how did I have 400 miles to empty now getting 313 miles to empty it's not consistent miles from full to empty
I believe that may have to do with the gas nozzles and/or the when the dispenser clicks off...Basically you're able to pump a little more gas in your tank from Marathon. So it's probably juys mechanics....
bdaniel230
Daniel
Middleton, Id
2022 Ford Maverick XLT -Hot Chili Red - 4k Tow Fx4
Has anybody found a popular gas station such as Walmart that you actually get the amount of gas the Maverick can hold Walmart has me at full at 313 miles to empty i have had Marathon give me 400 miles to empty but Marathon Gas stations isn't that popular
It has to do with the octane rating of the fuel as well as the amount of ethanol that is in it. If you get lower mileage, probably using the unrecommended octane rating of 87. Higher mileage is probably 89 0r 91 octane. I use 91 octane non-ethanol fuel in my EB Mav which gives me between 27 and 30 mpg, on the dash estimator, and I try to never run ethanol because it can seriously cause Turbo failure in this tiny turbo.
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
Asking since Marathon gives me 400 miles from full to empty and Walmart gives me 313 from full to empty what place would you most likely find that would also give 400 from full to empty ie shell,bp, etc
You're most likely filling when your average MPG is high at Marathon. Going from one brand to another should not change MPG if the same octane is used.
shrek
Jon
Alhambra, IL
2024 Mav Lariat Lux FX4, 4k tow
Driving Habits? More than likely
Timothyd
I fill up at Costco on top of the mountain. Sometimes I get 600 miles to E.
Old_Norm
Norm
Columbus Ohio
OP, I think I found your problem.
Ford Maverick Maverick Gas gas leak
Ranch
Sacramento CA
2023 Marverick FX4 4K
Hows does my Maverick determine the amount of ethanol in the fuel system?
I'm in California where I can't buy non-ethanol fuel. How long do you think I can go before turbo failure?
Dudley
Doug
Indiana
2003 Grand Cherokee
Question. Here in Indiana for every lawn mower and trimmer and other small engines that I have seen the manufacturer recommends using non-ethanol fuel and here in Indiana many, maybe most gas stations provide non-ethanol fuel since when small engines like that sit, the Ethanol residue can gum things up quicker. More expensive, but for me a five gallon container is good for several months of mowings so that is what I get. But not available in California?
Dudley
Doug
Indiana
2003 Grand Cherokee
Yep, my wife is a long-time company member (27 years now) at OSF. Coos Bay rocks!
My mom grew up in Coos Bay. My dad, from Pennsylvania, met her there while serving there as part of the Army Coastal Guard because of Japanese subs coming close, and them floating bombs on balloons to the coast, after being in both Africa and Europe in WW2. After marrying the moved to Pennsylvania and moved back to Coos bay when I was 1.5 in 1950. Lived there until 1979. Gotta admit, I miss the coast and lakes, and the fishing and crabbing and digging clams and ...
Ranch
Sacramento CA
No non-ethanol gas in California other than very expensive and limited availability racing fuel.
Also, beginning this year, you can not purchase any new gas powered lawn equipment in California so eventually it wont matter if the manufactures say to use non-ethanol gas.
My Maverick and Me
Greg
San Diego, CA
2022 XLT, Ecoboost, AWD, FX4, 4K, Area 51
Apparently your were going all uphill with the Walmart gas and the down hill return trip with the Marathon gas. :unsure:
AutobahnSHO
Will
S.Carolina
Maverick, Miata
CA is crazy, but only just recently are there a FEW stations around here in SC that also offer non-ethanol for more money.
