Manual Rear Sliding Glass worth it?
NewcMaverick
Kyle
Indiana
Cruze
I called and added it to mine today. It seems like A LOT of people think they'll use it, so I added it for re-sale value. I didn't initially want it because the truck has AC. I've only ever used the rear window on my Ranger for air circulation. I could see it being nice for dogs or other things though.
Hingeman
Ed
Goodyear Az
SIlverado
Did anyone else notice? When I built my Maverick and added the rear window. In the details it lists the window twice. Once as in interior add-on and also as an exterior add on. Also charged me $155 twice.
notfast
Los Angeles CA
'26 XL hybrid AWD 4K tow
I wasn't a fan of sliding windows, or at least the old framed-style. In my experience, they rattle and leak water. Haven't had a late-model Ford with the recessed slider.
I'm not a fan of carrying long materials inside the vehicle. I'd rather not take a bundle of pipe or a couple 2x4s to the neck and lose control of the vehicle. It's a lot easier to safely secure materials to a couple roof rack crossbars or a headache rack than try to rig something with the grab handles, seat rails, or similar.
bentley72
Andrew
Columbus, Ohio
2026 Ford Maverick Tremor
It was that way on my online build, but when we entered it into the computer to place the order I was only charged once for it
glider
So Cal
2002 4runner 2019 Honda civic
Hope you remember to close your manual slider.. I like the idea of the power slider on the Lariat. Makes it easy to open and close for ventilation. My 2002 4runner has a power back window that I use all the time.
Sykotyk
Ohio
I wasn't sure if I would like it or not, but my old f150 has no ac and used to the old 360 air. Three window open at 60mph. Just opening that little window with the side window cracked pushes through a lot of air. Will like it in the spring when it's too hot for heat and too cold for ac and helps with the hybrid setup not running either.
rtkegger
Blue Springs, Missouri
2013 Silverado
I have had full size crew cab trucks with and without a slider. If you try driving a crew cab with the front windows open and no slider to open, the wind buffeting will drive you crazy. I assumed the same issue possible on the Maverick, so I ordered a slider.
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
On xl you have to get cp360 to get the rear window, seems crazy. I dont really want 360 or want to hold up my build. Would get just the window option though if I could, really like the power slider in my f250.
Rentman1225
Greg
Rockford, IL
Forde Maverick XLT LUX
I ordered the mauanl silder on the XLT since both my other trucks had sliders. I use them a lot passing through long items.
However, after I ordered I saw how small the slider was and saw how it had glass above and below. I think I would be afraid to pass anything through it. I left it on the order because it was easier than changing the order.
I keep my vehicles a long time and on my current truck the slider rear window along with the side windows is the only form of AC I have. :)
Barracuda340
Abilene Tx
I did not get the sliding rear window. Went with solid glass. When the XL stated you needed CP360 to get it, I said forget that. Then I upgraded to an XLT and forgot to check and see if it could be had as a stand alone option. I figured it would require CP360 there too. Oh well you live and you learn I guess. If I decide I want one later on, I can always have a glass place glue one in.
Harleystreetbob
mike
moncton newbrunswick canada
harley electra glide maverick hybrid xlt
I had power rear sliding window in the ridgeline I used quite often but the manual one in the mav I have left open a few times but is too small for anyone to crawl through,its great to have for long items and really helps with the mav cause wind buffeting is horrible on our trucks
gte105u
Katy, TX
When I rented a Ridgeline with sunroof and power rear window, I opened the rear window and tilted the roof. Nice fresh air and very little noise even on highway. Between that and the dog who is a fixture in the back seat on the weekend I'm looking forward to a power rear window.
Bob The Builder
Butch
Vermont
My arm is too short.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
I originally was a fan and have it on my current Maverick but it turns out to be useless for me and my MY23 Maverick that I will be ordering on 8/2 will not have the window.
My reasons is that it is too small and too high to be useful for hauling long items from the bed through it. My old 1998 Ranger has a much larger and tall sliding window that was useful but the one on the Maverick is useless.
