Mabett Truck Bed Divider for Ford Maverick Available Now!
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
Hey everyone,
Introducing our new product--- Mabett Truck Bed Divider, built to elevate your hauling and storage game to the next level. This custom-fit divider is a game-changer for those seeking unparalleled functionality and convenience.
Buy directly via https://www.amazon.com/promocode/A1Y7CMDOT56NH5, 30% discount exclusively for MTC.
Key features
Versatile Options
: Choose the divider with or without rails – catering to all Maverick owners.
Flexible Mobility: Easily reconfigure cargo layouts for convenience, with the ability to securely fix at various positions on the rails.
Multi-functional Utility: Vertical or horizontal panel placement with molle panel design for versatile usage.
Durable Materials: Made of heavy-duty rust-resistant aluminum alloy for long-lasting use in all conditions.
Enhance your cargo management with the Mabett Truck Bed Divider – offering adaptable solutions for every Maverick owner.
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_3442
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_3312
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_2504
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_3421
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_3424.JPG
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_2547
Ford Maverick Mabett Truck Bed Divider for Ford Maverick Available Now! IMG_3034
Justin says...
Justin
NC
'22 Ranger XLT
This is a much better idea than your hitch area filler, I'll give you that.
You know, we still need something to fill in the big gap behind the driver's side rear tire so dirt/mud/rocks don't fly up into the underside of the rear bumper.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Hey everyone,
Key features
Versatile Options
They look awesome.
Billy2mav
William
Abington
Hey everyone,
Key features
Versatile Options
Hi mabett , i would like to respond to " Mabett stained fender flares"
TORQUERULES
Ford
I like this, but it looks like it would rattle pretty bad back there.
Montana
Does it require unscrewing to accomplish the transition from up and down?
Some sort of pull tabs or hinges would be a much better option. A pull to release and lock into either position makes more sense for this application. Same with sliding back and forth.
I'd be interested if those were integrated in here. 100% I'd buy that and swap out my ratcheting divider.
MABETT
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
Nice! Will this work with Unistrut rails?
We have not tested it. You can take a look at the installation video.
MABETT
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
I like the concept but just to clarify, all adjustments and positional changes require a tool to do so?
Yes, it requires a tool.
MABETT
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
It is in development now.
MABETT
MABETT
Diamond Sponsor
Ryan
China
www.amazon.com
2023 MAVERICK XL
It requires unscrewing the bolts.
Maverickman74
Shane
Maui HI
Cool idea having it be a folding platform, construction looks great too. However I do think you will do alot better with a spring loaded pin or bar to lock it in the different positions. On the other hand we got enough of the "Make it with Maverick" crowd around here, someone will source a suitable pin and mod theirs.
AceGoliath
Charles
22 Maverick XLT, 21 Bronco OBX SAS, 10 Fusion SE
I agree with the others. There needs to be a different way to secure the divider when flipping the divider up and down.
How many times can it be used before the screw strips and/or rusts up. Lose or break the tool. Too many variables.
Would not be so great fiddling around in a negative degree day or 100+ degree day to unscrew/move divider/screw each side.
Some sort of lock pin setup or if it absolutely needs to be screws at least gripped/knurled or hand knob screws.
Deleted member 5597
Guest
Nice product, but like others, a push, pull spring pin would be a much better solution than having to unscrew every time you make an adjustment. Take a look at the handles on the bed rail itself. Those handles pull out so you can reposition them and lock into place where the holes on the rail are.
Help me understand why one would need to switch to horizontal and put things on top of the divider w/o a way to secure the cargo? Stuff will fall off while traveling with an unsecured load. I imagine if one were to use ratchet straps from one end of the divider to another, that would increase the chances of it bowing and/or breaking.
And speaking of bowing, if this bed divider is made out of ABS plastic, it will definitely dry out and crack in hot and humid locations.
