MABETT - NEW SIDE MARKER LIGHTS REVIEW
Captain25
Ben Anderson
Charleston, SC
2013 Toyota Prius
i know there are a few of these out there but without reading through all of them I thought I'd let folks know what I thought about my install that I just completed.
I had the original version of these lights and of course one flooded so I took advantage of the refund and discount offer and got these new ones. At first glance they are built a lot better and appear to be well sealed so hopefully the water penetration issue is done. The set up was just as easy as before. Once I figured out the directions (more on that later) the plugs were a lot easier than the in-line splice method from before. After what could have been a 15 minute install the lights were up and running. I like the sequential illumination. makes the product look more quality. I think since I have the black appearance package on my 2024 Maverick these look a little better.
That being said the only things I would change are:
1) Better installation instructions - The graphic image of the engine bay and the wiring diagram are backwards. I couldn't figure out how to route the wires the way they were showing until I realized the image was wrong. There are letters showing different parts but no designation of what those parts actually are. Again, with a little thinking I got it worked out but if they want to sell these as truly plug and play then folks who can't work out the diagram will be lost.
2) Include zip ties to clean up the wire mess under the hood - There is a lot of extra wire left over that needs to be cleaned up including what you can see in the photos below.
- PHOTO 1 - Engine bay after final install to show that it can be organized. This is really important if you ever have a pro working on the engine. There is enough going on in there to worry about wires getting in the way.
- PHOTO 2 - Hook ups behind the driver side headlight.
- PHOTO 3 - Hook ups behind the passenger side headlight.
- PHOTO 4 - Instructions reversed. At least with my lights, the driver side setup is shown on the left of the image.
- PHOTO /VIDEO 5 - Shows sequential illumination, pretty cool.
- PHOTO /VIDEO 6 - This very light gauge wire has to stretch from the drivers side tot he passenger side. Without zip ties this can get messy. Specifically in the middle, because the wire is such a small gauge that it could get pulled into the radiator fan.
- photo 7 - My solution. Be sure to cut that zip tie clean so you don't scratch yourself later!
Last helpful hint. If you had the the first version of these lights then you now are left with cuts in the wiring from the previous install. I suggest picking up a roll of self-fusing, waterproof tape. Ordinarily I'd use heat shrink but since you can't slip that over one end of the wire, this tape is the next best thing to keep that wire together and sealed from water causing a short.
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW IMG_4799
RainFall
WA
Thank you so much for the detail review and instructions. I've been waiting for this.
I still love the old design. It's brighter than I would like because the width of the white light is thick. If it's narrower, Im assuming it would be dimmer at night.
Regarding the condensation, I drilled a tiny hole outside of the light at the bottom of the white area. This allows the air to circulate and it's been clean since. I know it's not an optimal solution, but looks fine to me since it's clear. If you drill it from the inside, Im not sure if it would look better.
That's why Im still ambivalent about getting the new one.
TwuckHappens
Jefe
2025 Maverick Lariat
What is the point of the red wire that connects the two sides?
I do wish they'd make a version that looks closer to the stock- the designs seem very niche.
Toddman45
St. Louis, MO
Ben, when I was installing mine, I took a roll of tessa fabric tape and covered all the exposed wires that didn't came completely wrapped from Mabett. Especially the single red wire running from ds to ps. Just to be sure the wire had a extra layer of protection.
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW 20250216_155935
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW 20250216_155857
MCIAD
Michael
Ventura County, California
2023 Ford Maverick Lariat
As a heads up they do have an install video on the sale page. https://www.amazon.com/vdp/058d2801f39f4584bfad9cf4235a73f1
Thanks for the tips and video link - I just installed mine and my in box instructions were also backwards - or at least to my untrained eye would have caused some issues. You're write up plus the video posted above were very helpful - 30 min install beginning to end. Getting the old clips out took the most time - they just didn't want to come out.
Thank you both!
Cubican
Pedro
Ridgeline, viper, c8
Great write up do agree with you about the instructions
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
25XLT
Rick
Washington State
2023 XL (Traded in), 2024 XLT (Traded in), 25 XLT (current and last)
Update: Mabbett refunded me the purchase price on these side markers and reported the issue to their design team, so I am happy with the outcome.
I have also installed these new redesigned Mabbett 2.0 version side maker lights as well on my 2025 Maverick XLT. Previously, I had the side maker lights version 1.0 that had the water condensation issue on the passenger side. The issue that I have now is that on the passenger side, the new side marker lightly rubs on the paint each time I open or close the door. I have tried to pry in over to the front as much as possible, but in so doing broke two of the tabs off inside. I think that it is a quality control issue. I am messaging Mabbett on Amazon for some guidance or replacement of the passenger side marker.
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW IMG_5513
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW IMG_5514
CurtisB
2023 Maverick XLT Hybrid
I sanded mine down. Just one millimeter did the trick.
Toddman45
St. Louis, MO
I have no issues with mine touching the door I have a strong 1/8" of clearance on each side when opening or closing.
However they are closer to the doors edge then the OEM inserts.
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW 20250214_221301
Toddman45
St. Louis, MO
Finally got a chance today to clean off all the salt with a pressure washer at the local car wash. For whatever reason I can't get my gas pressure washer to start, God I'm ready for spring!
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW 20250223_143733
25XLT
Rick
Washington State
That is great you did not have any clearance problems. I wonder if that means that panel gaps are not necessarily uniform on the Maverick from one year to another? Where did you find the color match to paint your side markers? The vendor offered to replace mine but will take a month to receive them.
MCIAD
Michael
I was just going to ask what kind of paint works best to paint that little silver insert. I want to do black to match the rest of the marker, but know next to nothing about paint.
Toddman45
St. Louis, MO
O'REILLY'S Dupli-Color rattle cans.
Ford Maverick MABETT - NEW SIDE MARKER LIGHTS REVIEW 17403553356486557354258722287429
