Side marker lights
White Thunder
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
Actually, that’s a video I used. I went back in and he had a footnote that saying that it was probably a different wire that could be used purple on green for those. I had the lights stay on, I tried that and it still didn’t work.
I had asked what video? Well I did see this and I told Fred I thought it was the best video I had seen. When I finally got my fender lights and installed them, the right side didn’t work for me either even with the different wire connection.
Louis
New Jersey
2024 Ford Maverick Lariat Hybdrid
Mabett has been a big friend of mine during my build. I have their mudflats, seat covers, side marker lights, and a couple of cab accessaries. Haven’t seen many people with the side marker lights but I assume the wiring for them is incorrect.
Ford Maverick Side marker lights IMG_2103
Ford Maverick Side marker lights IMG_2102
Ford Maverick Side marker lights IMG_2225
Ford Maverick Side marker lights IMG_2210
White Thunder
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
your right on the side marker lights . The are quite a few of them out there, with the passenger side wiring being messed up.
tom lepree
tom
florida
2022 maverick hybrid
installed the mabett side lights ,passenger side had a lot of condensation and filled with water.send back and replaced the passenger side is doing the same thing???
Chris_G
NOVA
C-6 Corvette
You're right, both sides should match.
Hrntfixr
Jacksonville, Florida
2023 Ford Maverick EcoBoost
Installed these a few months back. They are bright as hell at night. I did watch a Youtube video to get the correct right side wiring setup. I also used some different wire taps. Was not happy with the ones Mabett sent. Video here from Fred's Garage
Now i will say this mine don't do the fill in like his does in the video. They just turn on with the running lights and blink with the turn signals. Mabett any answer for that?
sfretwell
Steven
Roseville. CA
2024 Maverick Lariat Hybrid
Just installed mine on my 2024 lariat and the right light stays on after the turn signal is shut off I did switch the wires on the headlights side to the 2 bigger wires and that did not change it. The light will turn off after several minutes. The left side works like it should. Come on mabett chime in i have the red wire unplugged for now. The pisser part about mabett is they have no contact information on amazon or a web page to send email.
I am having the same problem. The left side turn signal works as intended as does the right turn signal The way I currently have wired the right side light, the light continually stays lit. Also seems that this wire is always hot
I assume I wired the right side wrong. I connected the wire to a large gray wire. Can someone who has had a similar problem tell me which color wire to be connected to the marker light?
White Thunder
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
🤓 Put the black wire to ground, just tie off the red wire, don’t use it, tie the yellow wire to one of the turn signal wires (I think it’s white with a blue leader). That’s what I did on my EB and it works great.
Alabama Maverick Owner
Bubba
Foley Al
2024 Ford Maverick Lariat. 2013 Smart car
If anyone is interested, Maybett has the marker lights on sale at Amazon for $45.99. I ordered an extra set for replacements when the originals crap out.
