Keys can be locked in the truck.
jabaill
Judith
Tucson
2025 Maverick XLT
🤔 My '23 automatically UNLOCKS the drivers door if the truck is running and I try to lock the door when exiting.
Not saying your truck isn't possessed, Lord knows they all seem to do some weird stuff.
Possibly another instance of depressing the MANUAL lock lever when opening the door? This has been mentioned here - seemingly to many times to count - next time it happens check the other doors. They MAY not be locked.
The search function is always looking for something to do....
Yes I locked myself out, but luckily the back door wasn't locked!
brlr2000
Bruce
2024 Maverick XLT Hybrid
Is it possible to order a stick-on keypad and DIY?
Yes you can order a stick on keypad. I believe the dealer has to program it generally if you order it through the dealer they can give you a break on the programming fee.
Check out Post #7 and #50 for more information.
Dang that sucks. On mine it won't lock if the key fob is still in the vehicle
Thank you for your reply.
Just so that you know. There are 2 WAYS you can lock your key fobs inside a 2022-2023 Maverick with a keypad.
Both my key fobs are on the driver's seat. I am locking the door using the manual lock lever. This is the most common way folks are locking themselves out of their Mavericks.
Using the keypad is another way.
Note Both my key FOB'S are on the dash.
brlr2000
Bruce
Thanks for the info
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
I have a '23 XLT with the hard-wired keypad. Why Ford discontinued this is beyond me.
Why Ford discontinued the wired keypad? Dollars and cents and they didn't think anyone would notice.
Good news. Ford is bringing the wired keypad back.
retiredmike
ohio
2024 Maverick lariat
My 2025 is the first FOB vehicle I've ever seen that lets you accidentally lock yourself out with the FOB inside. Has happened to me a few times because the doors seem to lock themselves arbitrarily. But I have luckily had my phone in my pocket and could unlock them through the app. But today I left both the fob and my phone in the car when I jumped out to move something and the door locked automatically behind me and I was locked out of the running truck. Had to call my wife to drive over with her FOB. My previous cars were unlockable when the fob was inside the car. You could lock them from inside but as soon as you open the door to get out all of the doors would unlock.
I also hate the arbitrary horn beeping that happens sometimes when you get out of the car and shut the door behind you. There seems to be no rhyme or reason for when it does that. I'm apologizing to startled bystanders all the time.
My doors do not lock if fob left inside. 2024 Lariat
Yes order one from dealer or Ford online.
To program enter the truck key code and within 5 seconds push the 1-2 key on keypad then within 5 seconds enter the numbers you want to use followed by pushing the 1-2 key on keypad also within 5 seconds. = BINGO you have programmed key code. (After you push the 1-2 button saving your desired key code the locks should cycle demonstrating success).
If you do not have the trucks permanent key code (came with truck on small tag). It is printed on the BCM located in passenger floor area on the side nearest the door. OR you can get it with both keys in key start trucks by inserting one of the keys without foot on brake turning to accessory waiting about 4 seconds when dash finishes "to start put foot on brake" pop up. Remove key then place the other key in and turn to accessory within five seconds (no foot on brake) wait for several seconds for a popup window which will say key code is nnnnn!
IF you have keyless start place the two keys in the bottom center of the console well pushing the start button without foot on brake sequencing like above example with the keys the button pushing is like turning key on and off!
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
How do you find the ‘truck key code’ ? What and where is it?
Ruppunc
Micheal
Troutman, NC
2025 Ford Maverick XLT
I've had my 2025 Maverick XLT for about seven months now. I love my truck. Inly thing I'm having a problem with is my remote starting and lock unlock from my phone has stopped working. What can I do about this?
