Is 12 volt battery for hybrid a AGM battery?
Oreilys sells the bxt battery bxt99rt4a and has good writeup on what it is. It is a "standard" type. Special made for high heat conditions. Read all the bullets on their site.
NoVaJimmy
KCMO
Lexus GX 460
Is it that hard to lift the seat and take the cover off to look? Fwiw the 12v on the eco says agm right on the top.
Not sure how that's possible unless it was replaced by the dealership but I checked a built 2023 Ecoboost's as built data last night and the BCM was specified for the same battery that 2022 Ecoboosts received from the factory, an enhanced flooded non AGM battery.
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
Seriously doubt it was replaced by the dealer, I just got the truck last week. Here is a pic of the battery, maybe its because I have AWD and 4K tow, dunno.
Ford Maverick Is 12 volt battery for hybrid a AGM battery? 1670508618344
NoVaJimmy
KCMO
Lexus GX 460
I have both and mine came with a flooded battery. Can you post a photo of your actual battery? Like I said, curious since as built data for the 2023 AWD I looked up would have indicated an AGM battery but it showed an enhanced flooded. If you did get an AGM and the BCM thinks it has a flooded battery then you're not really benefiting from having an AGM
thevol
GA
Havent starting messing with forscan yet but will check when I put my cruise control switches in.
Ford Maverick Is 12 volt battery for hybrid a AGM battery? 1670509224736
NoVaJimmy
KCMO
Lexus GX 460
Thanks and good for Ford for making the upgrade. While in there I'd definitely make sure the BCM is set for an AGM. The as built data for the in transit 2023 FX4 I looked up last night was set for an enhanced flooded battery so if it does have an AGM the BMS isn't taking advantage of the superior charging characteristics of the AGM and charging it like an enhanced flooded battery.
thevol
GA
Thanks for the tip, I may go ahead and check today in forscan, think there are a few settings I can play with...havent used it since I got my super duty a couple years ago so prob need to get the license upgraded. Is anyone keeping a spreadsheet of all the forscan changes you can make, I know there was one for my other truck out there...
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
The AWD and 4K tow is an EcoBoost. They have an AGM battery.
TheWizziard
Texas-RGV
Not sure where you get your info from, but the hybrid 12v battery is an AGM.
I got the information straight from the 2023 owners manual.
2.0L ECOBOOST - AGM battery: BAGM-348H6-760 (AGM in the part number)
https://parts.ford.com/shop/en/us/battery-and-related-components/battery-7862483-1
"AGM" is clearly printed in large letters on the top and side of the battery
Ford Maverick Is 12 volt battery for hybrid a AGM battery? 1670513031387
Ford Maverick Is 12 volt battery for hybrid a AGM battery? 1670513069458
2.5L, HEV - Standard Flooded Battery battery: BXT-99RT4-A
https://parts.ford.com/shop/en/us/battery-and-related-components/battery-7868851-1
"AGM is nowhere top be found on the battery
Ford Maverick Is 12 volt battery for hybrid a AGM battery? 1670513150257
Ford Maverick Is 12 volt battery for hybrid a AGM battery? 1670513248304
Is it possible that ford has shipped hybrid Mavericks with different batteries?
Possible, yes.
I can't tell you what you have in your vehicle, you may have an AGM, but various members have shown photos of their "BXT-99RT4-A" battery in their hybrids. This is not an AGM battery.
UPDATE:
The 2022 manual shows a Standard Flooded Battery for the EcoBoost: BHEF-48H6
The 2023 manual shows an AGM battery for the ecoboost: BAGM-348H6-760
Nowhere do the manuals show an AGM for the HEV.
Are they shipping with AGM's???
At this point the best way to know what you have is to lift the seat or raise the hood.
The AGM' are clearly marked.
GPSMan
Many
AGM is an optional / alternative battery for the EB.
Maybe it was stock on higher trims.
Or MAYBE the regular flooded battery was a constrained item and they ran out and went to AGM to keep the assembly line going.
What this thread proves is: just because you see something on YOURS it does not mean it applies globally.
jsus
2022 Ford Escape Hybrid AWD
Possible, yes.
If anything, they'd try to get away with a cheaper 12V battery for a hybrid because
1) It doesn't have a conventional starter that runs off 12V; that's handled by the eCVT, supplied by the HVB. No need for high cold cranking amps as a result - cost savings.
2) It doesn't need to keep the 12V system up and running when auto start/stop is active; the HVB charges the 12V battery the entire time the vehicle is on
3) Essentially, it's used more as a float and to power the electronics when the vehicle is off.
AGM would generally be more of a benefit for the EcoBoost with auto start/stop features.
NoVaJimmy
KCMO
Lexus GX 460
That's all over the place then because my AWD 4K tow ecoboost did not have an AGM from the factory, it had an enhanced flooded battery.
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
Possible, yes.
I stand corrected. Thanks. When I took delivery in May '22, I did like alot of owners do. I familiarized myself where things were under the hood, location of spare tire, where to find the 12v battery under the seat, etcetera. But wether or not it was an AGM was not even on my radar.
For some reason I thought it was an AGM, probably from (mis)info here at MTC. I just came back from checking and it is indeed not an AGM. It is vented to underneath the vehicle. Ultimately I guess it's not a big deal. Fortunately mine has not suffered from any low voltage condition in well over 15,000 miles.
TheWizziard
Texas-RGV
It is all over the place.
Today I found out that:
Johnkn
MD
I’ve not seen a single instance of actual proof that hybrid Mavericks ship with an AGM battery despite what some people (above) claim. Mine certainly is a flooded battery
