- First Name
- Chris
- Jul 19, 2021
- Sacramento California
- Prius LE, Ford F150
Its really not that hard to do, or expensive, its just a knuckle ripping PITA ! You will have to remove door panels and the roof liner. One nice thing, in a new car, all of the plastic clips are new, and pliable. In an older vehicles, these are much more prone to snapping. Its not important to cover the entire door skins from the inside (which is fortunate, because that would be darn near impossible) but (and this is kind of an oversimplification, but just to make a point) say you are only able to cover 40% of the inside of one of your doors.... This might be 90% effective. You do need some deadener inside of all 4 doors, your roof, and the back wall of your cab.
As for brands of sound deadener, if money doesn't matter to you, Dynamat works great. For something which is a lot cheaper, and IMPO, works just as well, I use Noico.
I went for years without sound deadener in my truck, and thought I was okay without it. But about 2 years ago, I sound deadened it, and now I can't imagine ever going without it again ! Not only does it give you a much quieter noise floor, so that you can listen to music at a lower level and it still sounds great, but also, you can blast loud music / bass, and greatly eliminate all the interior rattles Even aside from music, if you just want a quieter, more peaceful riding experience, deadener all the way !
PS, before I deadened my truck, a light knock on the door sounded like knocking on a steel trash can. Now it sounds like a heavy, solid core wooden door
