Hybrid Revs Coasting Down Hill
Grabber Rick
Rick
Sarver Pa.
07 Focus wagon 06 Silverado 4x4
To all members with a hybrid. I have a 2023 with just over 13,000 miles on it. While going down a hill in normal or eco mode my truck revs like I am in a low gear. If I had a tachometer it would be showing very high rpms. I let my truck warm up then drove about 9 miles down the road. When I went down the hill my engine was definetly coasting with the rpms pretty high. It happens on a hill I go down by my house. It sounds like the truck refuses to shift into a higher gear. I know it does not have gears but near the bottom it will just stop that high rpm sound. Feels like it just shifts to a higher gear.
Has anyone else with a hybrid experienced this? Thank you and I will wait for some answers. Should I be concerned? Is this normal? My experience with my 5 speed Focus when shifting to a lower gear creates a high rpm. So does a automatic when pulling it into 2 or L creates this reving high rpm also. These scenerios are expected because I put it in a lower gear. My hybrid does it just by coasting down hill. I even pushed the throttle a bit and it still was reving like a low gear.
Ray-n-AVL
Ray
Asheville, NC
2024 XL Hybrid (Black), 2009 Yamaha V-Star Tourer
Sounds like Hill Descent Control (If Equipped). Check your manual.
Propane Burning Man
Will
Gold Hill, Oregon
24 Maverick Lariat, 007 Mustang GT, 2015 Propane Transit 150, 1970 VW Dune Buggy
I am not convinced what you are hearing is the ICE revving. Your ICE should not even be running going down hill, should be in electric mode. I have plenty of hills in my area and quite often I put it in L so I am not on the brakes going down hill and I can hear the regen braking revving the regen motors and it sounds similar to an ICE revving.
IT IS NORMAL OPERATION for a hybrid (even without Hill descent) going downhill when the battery is at capacity. When you're coasting regen is on if the battery is full the ice engine will rev (Engine Brake) to try and slow things down. I hope I explained it correctly.
You're Not hearing the electric motor revving during regen going downhill. It's the ICE
Clarkdonbran
Scary, but normal. I’m dumb, but I think your engine needs to expel the excess energy created by the regen.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
NORMAL OPERATION for a hybrid going downhill when the battery is at capacity. When you're coasting regen is on if the battery is full the ice engine will rev to try and slow things down. I hope I explained it correctly.
Yup, just a case of engine braking.
Normal - even though it sounds terrible when around 4500 RPM on some steep downhills.
Wasting the generated electric that can't be sent to the battery because it's full.
You braking - or the Hill Descent Control, will both cause regen and that effect.
At some point the HDC won't be enough to keep the speed, you'll have to dig into the brakes.
Which changes nothing on that RPM.
@Propane Burning Man - you've been hearing the sounds of ICE revving this whole time.
Ever been going 50 mph, and slowed up enough to slip into EV mode and keep the power up enough to stay there?
That's the sounds of the motors at high speed - almost silent.
Propane Burning Man
Will
Gold Hill, Oregon
I did not know that. Does the ICE actually fire up? In other words, are the spark plugs sparking and fuel being injected and burned just to slow the truck down? I hope the answer is no. ✌
No fuel.
Purely just air braking.
Though - I have wondered what happens when the ICE hasn't met say the min 120F to be turned off yet in the cold, but you hit the point of needing to waste regen.
I've seen that a couple times this winter - but wasn't logging to review, or forgot by the end of the drive to review.
I'm guessing the fuel stops while it engine brakes, then ICE fires right back on for the needed heat.
Marty
2026 Ford Maverick Tremor
“Normal - even though it sounds terrible when around 4500 RPM on some steep downhills.”
“Though - I have wondered what happens when the ICE hasn't met say the min 120F to be turned off yet in the cold, but you hit the point of needing to waste regen.”
I still can’t get my brain past the fact that this ICE can withstand this RPM when that cold.
And not wear at a very accelerated rate.
How are the rings not bypassing oil ? At those temperatures ? What was the secret to building an engine that can do this?
I mean, obviously Ford did it.
Is it the advanced oil’s we have now ?
Jay H.
Jay
Santa Cruz CA
2025 Maverick XLT with Luxury pkg and coPilot 360
Yes, mine does the same thing. When on a long downhill, once the battery is full the ICE engine will rev up for engine braking. I guess the algorithm really doesn't want us to use the brakes. Anyway, that's just what it does, no harm done.
SteveM
Maryland USA
2018 Silverado, 2025 Eruption Green Lariat Hybrid
Your truck will charge your HV battery, while going downhill. It varies the charge rate as required to help hold your speed even. Once the HV battery is fully charged, the ICE kicks in to utilize "engine braking" to help reduce your speed. It sounds like it is reving, because it is. This is normal operation. I drive over 2 mountains on my daily commute, (2 each way, so 4 mountains total round trip). Yhis happens 4 times per day for me.
Will,
Deceleration fuel cut off was basically implemented around 2010 on fuel injected vehicles.
Here's a little more information.
Ford Maverick Hybrid Revs Coasting Down Hill 20260208_083725
The ice will rev up WITHOUT GAS OR SPARK COMPRESSING AIR TO BRAKE!!! It will only do so for a time and will add gas and spark as needed. The oil pump is working while ice is compressing air.
OB1e
Massachusetts
CG LUX XLT
Going down a long hill, turn the L off, otherwise it will sound like na airplane taking off
