Hybrid going dead
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
So my hybrid has gone completely dark 3 times in a week. The dealer said that the 12v battery checked out good. However, the truck comes back to life when I hook up my jumper battery. The dealer has ordered a new 12v battery cable overlay per CSP 22B39 which should be in next week. If jumping it results in it starting, I don’t understand why the battery would test OK. Anyone else experiencing this issue? I’m about ready to go to Autozone and replace the battery.
AF Blue
US
NA
Could be the harness is bad per the CSP and
the 12v battery cannot charge like it's supposed to.
Search the CSP to find threads like this:
https://www.mavericktruckclub.com/f...mer-satisfaction-program-delivery-hold.32720/
Ford Motor Company
Official Ford Account
Dearborn, mi
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
VIN # 3FTTW8E36NRA25635
Dealer is:
AutoNation Ford Wolfchase
7925 Hwy 64
Memphis, TN. 38133
901-209-1257
Thank you.
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
Also, the CEL is on. Code is P068A.
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
Dandy Mav
Bellingham, WA
2023 Maverick XL Area 51
I had the truck go dead yesterday. It's the second time, but it's been 6 months since the first. Both times were with short interval drives and the blinkers going for 30 to 60 minutes for a few of the stops. Sort of seems like using the blinkers (with a trailer hooked up) might be contributing to the battery dying. I'm a little bummed this is an issue still... Good thing I had the portable jumper though!
The Real Maverick
Jack
ECM/PCM Power Relay De-Energized - Too Early
Sets when the non volatile random access memory write did not complete successfully after the ignition key was turned OFF, prior to PCM shutdown. This DTC also sets when the PCM power relay is de-energized too early.
My take:
A bad 12v battery or 12v battery connection could be responsible. Using a jumper could be a work around if you went under the hood, or you could have wiggled an intermittent connection if you went under the seat.
Red Ryder
United States (TN)
22 Maverick XLT Iconic Silver
Yes, you have the harness issue and your service department is on the right track for successful resolution. Be thankful for them.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
60 minutes x at least 8 blinker lamps (2 front, 4 tail, 2 trailer) x 12W x 50% duty cycle = 2.88KWH (call it 3.5KWH including the battery minder, the computer and probably a few other things that you left on) for each stop. And that assumes that your trailer lights are only 12W and not the older-style 21W or 50W. That's a lot for you to expect out of a little battery. Maybe swap out the bulbs for LEDs to get to 1/10th of the battery usage, or get a much bigger battery.
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
So it just went dead again. My voltage meter showed 11 volts. I’m hoping Ford will also replace the battery. In any event, I probably need to wait to replace it until the cable/harness is replaced.
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
So after 2+ weeks at the dealer, they have all the parts for everything in the attached photo
Ford Maverick Hybrid going dead IMG_2499
I pick up a loaner tomorrow. Hoping they finish with it next week.
rtucker5612
Roger
Memphis, TN
2022 Maverick XL
Well. I spoke too soon - I just picked it up! Woohoo!
millertyme15
Bobby
St. Louis
Nissan Murano, Chrysler 200, Jeep Wrangler
My dealer put in a new battery. Looks like a Heavy Duty Battery that was installed. Originally battery was showing some failures from some report they pulled on my truck diagnostics.
