How to Soften / Dissolve Spray in Bediner ?
b plough
b
georgia
maverick xl
Does anyone know what will soften it or remove it.. They spayed the holes in the bed got to tap them out but liner is to hard
The Weatherman
Dean
KY
Who did the job?
bearsfan647
Detroit
EBike - Future Ford Maverick!
take it back and tell them to
Jatrax
PNW
2023 VW ID.4
Harder than your taps? I guess I would treat it the same as if a bolt got broke off in there. Drill it out carefully with a drill bit smaller than the threads then use a tap to clear the threads. Unless I'm missing something.
But if it was done locally, you might ask them to fix it.
BoboysTruck
Virginia
F150, Focus, Juke
If you decide to DIY and go the drill route as others suggested, don't drill down too deep or you're going to need a
new gas tank.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
Had the same problem. Went back to my Linex dealer and he showed me that I needed a much more powerful drill and short stubby socket set. My drill could not penetrate the liner and my bolt just wabbled round the hole. He just did it for me with his much more powerful drill and short sockets, in less than 10 minutes attached 6 bolts thru the SIBL.
Pretty sure applying a softener or any chemical to the bedliner will royally screw it up and stain it. Trying to drill out some of the SIBL would probably strip the threads.
The Weatherman
Dean
KY
Ford factory liner
I would take it the dealer then and see if they can correct it. Should be simple a specially if they have their own body shop.
Timothyd
Heat would soften it up for sure. Perhaps a hot nail to open up the hole and then a plug tap to finish cleaning it out. Don't go too deep with the tap.
Johnkn
MD
At least they won’t get pregnant..
