How long should I let it idle?
Brett
Lawrenceburg IN
I do like my Maverick and it is the first vehicle I have owned with a turbo. My question is how long should I let it idle after returning home from work, doing errands or whatever it was as I heard different answers as to how long it should be. I have heard 30 seconds. one minute and up to five minutes to let the turbo cool down some before shutting the engine off. I usually wait at least 30 seconds if not longer before I shut the engine off.
Carlitos_92
None of that is necessary unless you are towing or racing, but I'm sure you will get a variety of answers here. :wink:
MaverickDragon
Grand Canyon, AZ
It depends on how hard (or not) it was driven beforehand.
Driving at low speeds the turbo would not be working hard, and temperatures are not extreme, but a long run at high speed on the interstate, or with repeated high speed runs between lights, it's likely more helpful to let the turbo cool down and minimize sudden thermal shock.
You get the same effect by driving sedately the last few miles on your way home.
No magic number, but general rule of thumb for a very hot engine would be a couple of minutes. Obviously it's all up to you.
Chops
Lobo
Unlike some others, the turbo is both oil and water cooled. No cool down idling is required at all.
The reason idling is beneficial (& recommended) for a turbo is that it keeps both the coolant and especially the oil circulating.
Me, I let the end of ride “high idle” finish if I’m not too impatient to wait the minute or less. I’m usually patient though.
Pointyears
South Central PA
I never heard of letting it idle after a drive but I usually auto start the truck 15 minutes before I go to work so that the oil thins before driving.
That's just a waste of gas, especially in Florida.
John R C
Broomfield, CO
2011 Subaru Outback; 2021 FR 30DS RV; 2025 Maverick Laramie Azure Grey
Heavy duty turbos, e.g. Cummins, have been oil cooled as well as lubricated and bearing housings could get pretty hot. Hot shutdown in severe cases could 'coke' bearings with oil residue reducing running clearances, bearing to shaft or housing as these were cylindrical plain bearings. Therefore idling before shutdown was prescribed. As the Maverick bearing housings are water cooled idling before shutdown for any length of time is not necessary. I'd do if if towing and immediately stopped but otherwise it's not necessary.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Let it idle until it is out of fuel, This allows the turbo to cool and prevents stale gas in the system which prolongs the life of the engine. I'm currently getting 3.2 gallons per mile but well worth it to do preventative maintenance.
:ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
Tim d
Alpena
Ram
You dont have to let it idle at all. Unless maybe you have been doing some full pull quarter mile back to back racing.
Gray Goose
RG
Wissota
I've been using that strategy for my snow blower forever. Tecumseh engine is over 30 years old and still going strong. I did rebuild the carburetor a few years ago. It doesn't have a turbo, but it's on my list for upgrades. 🤔😉
End goal:
Ford Maverick How long should I let it idle? 1772550057726-nn
Rwills
Ron
Blue Ridge Ga
2024 maverick
None unless you were reving it hard
