How long does brake pad last on Hybrids
dsford
Dean
Bowie, MD
2024 Ford Maverick XLT
Just wondering if anyone with a Hybrid can tell when they had their brake pads replaced. I have a 2024 Hybrid with 29K miles and my pad still look like new. Would like to know how they’ll last.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
You only use friction brakes when under 4mph or when braking hard. The brake pads wear will consequently be very highly dependent upon how you drive. If you hyperbole you could probably expect to get 200k out of them, and if you drive like an ass then you'll only maybe get 30k.
Mavster Mechanic
Hybrid
200,000 miles on my last Ford Hybrid.
So anywhere between 2x and 4x as long lasting as a regular car depending on how you drive it.
Mavster Mechanic
Hybrid
The word is "hypermile".
Quest
Rotors will rust out long before pads wear out
vandeda2024
US
2025 XL Hybrid, AWD, 4K
How long until the rotors get too rust pitted from hardly using the pads might be a better question 🤔
I ran into this exact problem with my Prius v. When I first owned it, I worked to minimize brake use and maximize fuel economy. However, my rotors rotted out in 2 or 3 years (I forget which), and I failed inspection. When I replaced the brakes, the rotors looked bad, especially the rears. After that, I made sure to periodically brake hard, particularly in winter since we encounter a lot of road salt, and I never had this problem again. Apparently, road salt eats cast iron pretty fast oddly enough lol.
Rlward
Hanwell, NB Canada
Honda CR-V, Fird Maverick XLT Hybrid
I had to replace the rear pads and rotors around the 55,000 kms mark I think. Work done by Speedy Auto. Front brakes were ok. Checked later by my Ford dealer as being ok.
notfast
Los Angeles CA
Basically forever if you don't live in the rust belt. I regularly serviced Toyota hybrids that had 200K+ on the original brake pads and rotors.
The brake service was basically...everything except the pads. Replace grease on the caliper slide pins, replace anti-squeak compound on the calipers, ensure the rotor isn't pitted or seized onto the hub, reassemble. And a brake fluid change every other year or so.
I usually get at least 1, of not 2, faster braking actions on each drive, due to people darting lanes and braking fast - so I get some higher speed action.
Face doesn't have rust, other areas of course do.
I figure it'll be interesting to get them off when the time comes.
At least the rims aren't sticking that bad yet on rotating.
Ryom
PA
Powerstop has two varieties of plated rotors (zinc & Geomet®) but they don't have the Maverick listed in their vehicle finder. It does seem to me like hybrids should be using corrosion resistant rotors from the factory, since regenerative braking and rotors rusting out early is a tale as old as time now.
WJOHNM
New York,LI
I get a lot of rust on the inside of my 4500-mile 10 months old 25 Lariat hybrid black wheels, the wheels are not steel must be coming off the rotors, don't drive much the last 9 years am retired never seen this before on other models I've owned, my last maverick 22 fx4 I had for 15k never noticed it, find it odd. Few people commented my wheels are rusting on your new truck.
Do they use the same rotors as the ECO model, obviously when I do drive its scraping the rust off the rotors and running down on the wheels.
