Hood squirts when braking in the rain.
MaveRichard
Rich
MI
2023 Ford Maverick XLT Hybrid
This happened on my Super Duty too.
It is always most dramatic on the first stop in the morning after a night of rain when the rain is beaded up on the hood.
mspmms
2022 XL Ford Maverick 🇺🇸
colinl
Colin
ICT
My experience has been that water collects a lot less if you have a properly waxed truck.
I know because I started the winter like that, and now I'm due for a re-application and I do have a lot more water pooling in the grooves on the hood. When the wax was in better shape (it still beads some, just less) the water moves off quickly even in the grooves so there's nothing to squirt.
Shakesbear
J. R.
Sorry for the terminology, but this is more of a squirt than a spray since it builds up water in the "performance dent" on either side of the hood, then when you brake that water streams toward the front edge of the hood and then the wind squirts it back on your otherwise clean windshield.
So my question is... do the hood guard/protectors for the front edge of the hood block the blow back "squirt" and allow the water to run off the hood cleanly when braking?
Water is wet ;)
SLJ
Elbridge New York
Maverick doesn't squirt as bad as my Bronco Sport did. That hood held a lot more water.
Optimus
MN
2023 XLT Hybrid
In all seriousness, my spouse and I have noticed this issue too (independently on our own). Things that affect it include driving speed, how hard it’s raining, and the amount of stop and go. I would say a good size cup of water, or larger, collects in each “pocket” and just kinda dances around (annoyingly). The biggest issue for us us it’s rather distracting, as this big blob of water seems to take on a life of its own and shouldn’t exist in the first place. Then when slowing down, it runs forward, catches the wind, and all comes splattering back into the windshield.
It got worse for us after applying a ceramic coating, as this causes the water move around and pool even more easily on top the hood. I had attempted to purchase a certain bug shield that curls up, rather than the typical styles that lay tight against the hood, in hopes it would change the odd air vortices. Unfortunately, that particular bug shield got tossed in the trash without being installed, due to it having the same defective manufacturing issues as reported on this very forum.
I am hoping another manufacturer will release a better style bug shield, as I would still like to try and solve this. It is honestly a bit distracting, including at night, as lights flicker off the puddles in weird ways.
ilikebike
2024 Ford Maverick Lariat Hybrid HPR w/ BAP
An object in motion stays in motion. So, when you brake, the water is still going the speed of the truck before the braking since there is little friction between water and truck. As a result, the water moves to the front of the hood until it hits the wind the truck is pushing through, which causes the water to spray back onto the windshield.
I haven't honestly noticed it. If it is raining hard enough to have water collecting on the hood, my windshield is likely getting wet from the rain itself and I don't notice the spray.
Interesting, that makes sense. Thanks.
It's not during heavy rain. Usually when it's after a downpour and it's not raining anymore but the hood is wet, or if it's a light drizzle and it's been long enough for water to collect on the hood. Both cases you've already run the wipers and the windshield is clear. It happens on my truck.
Not a problem, just curious the mechanics behind it. Never happened on any of my other vehicles before.
SiGmA_X
PNW
If there is water on the hood it's going to come towards the window under heavy braking, it's just physics. I know some people said that the front edge guard does reduce it somewhat.
Welcome to the internet, there are a lottt of physics deniers out there :p
MavTime
23 Maverick Hybrid XLT
Sorry, I should have titled it "Hood squirts when braking after a rain." It is usually with water beaded up all over the truck after a rain, and as you drive down the block you run the wiper once and clean the windshield, but then when you stop at the end of the block SQUIRT! I guess I haven't has a car with this flat of a hood, but I really think it is the hood dents that pool up enough water to do it. I am surprised some said that the hood protector didn't help, seems like it would.
commadorebob
The hood protector is too low to make a different in the air stream. And depending on the amount of water, it would just flow over it.
