Hard to find EB Ecoboost engine cover found new online
absmith
MO
Well used stuff
I was able to remove the urethane. The cover is slightly discolored in a couple of spots but overall it looks fine. It works for me, at least for now. I did not want to deal with the hassle of trying to return it. I'll be curious to hear if you have the same issue.
Ford Maverick Hard to find EB Ecoboost engine cover found new online Mav Engine Cover
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
How do they attach? Pics of what is needed, screws ? Or just a clip on? Thanks.
24atlasmaverick
Christopher
Buffalo, NY
2024 maverick XLT, Lux, FX4, AWD, 4K
There’s a plastic stud with ball on top, a bolt with threaded stud, and a nut. Not sure what the part numbers are off the top of my head but search engine cover on this forum and you’ll find what you need.
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
Wow, I was not expecting that answer. The cover looks great. What did you use to remove the rubber paint? Was it a PITA? I will definitely report back with an update when the cover arrives. Thanks!
Camdak
Jay
Castlegar B.C.
2024 Maverick
This cover looks great compared to the other ones that I searched for as I was told to on this forum as mentioned in above posts. Wouldn’t mind having one of these! Looks like it should a stock piece 🤔
jonshep
SW Oklahoma
$150 to $170, and a potential 100% tariff, WOW! If I get to needing one, it will be made out of plywood and covered with Reynolds Wrap.
A.Bursell
Stanwood, WA
They can be found used- they were installed on hundreds of thousands of vehicles. I think I paid $75 shipped for mine and it's like new.
absmith
MO
Well used stuff
Just my fingers and an x-acto knife in the intricate areas. Once I was able to get under an edge it pretty much peeled off. A little heat probably would have helped but it came off. Yes, it was a PITA but no one has ever accused me of being patient.
MetalThunder
MetalThunder
Blue Water Area / Thumb Coast "Mishigami"
www.automobile-catalog.com
2024 Iconic Silver AWD XLT 4K Lux Ecoboost
Searched for the Ecoboost cover to no avail in 2022 -
Last Summer (23) pulled the trigger and put the Lincoln cover on. Seemed to quiet the engine noise a bit and it cleaned up the engine bay - looked great. Then ended up removing it that fall after a quick inspection revealed a rodent turned it into an apartment and acorn storage unit ;)
My suggestion to anyone using one - remove and inspect what's going on under there - especially if you are rural
Cheers
Dale Baker
Dale
Tulsa Ok
2024 Maverick XLT
Just be careful with the payment method you used. Monitor it closely for a while.
With questionable sites, we go buy a gift card for a few bucks over the amount of the item. Use the gift card then put the balance of the card on Prime.
CarbonGrayFX4
Luke
Virginia
Great, I was wondering if the paint might be a flex seal or plasti-dip type product. Maybe they applied it for customs reasons? My latest tracking update reads "arrived at local airport" so hopefully I will have an update soon.
CarbonGrayFX4
Luke
Virginia
The wait is over. I honestly am not trying to ruin anyone’s day but the Aliexpress cover is 100% a knock off. I have both side by side and it is painfully obvious. The major give away is the “CCC” on the Ali and the lack of a patent number. A lot of other give aways. That being said it is a decent enough copy. Damn, I’m sorry bros. If I hadn’t been so fortunate as to get a genuine one on Ebay, I would go the Lincoln route before they disappear too. My main reason for the cover is for sound deadening which it 100% affects. Anyone who says otherwise is a crazy person. I will probably use the Ali cover as a test for more sound deadening efforts. I am thinking of coating the underside with boom mat spray.
Ford Maverick Hard to find EB Ecoboost engine cover found new online IMG_3376
Ford Maverick Hard to find EB Ecoboost engine cover found new online IMG_3375
Ford Maverick Hard to find EB Ecoboost engine cover found new online IMG_3371
Ford Maverick Hard to find EB Ecoboost engine cover found new online IMG_3370
Ford Maverick Hard to find EB Ecoboost engine cover found new online IMG_3372
Ford Maverick Hard to find EB Ecoboost engine cover found new online IMG_3374
