Fuel additives - do they work?
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
Sea foam and Lucas etc. fuel injector cleaners, do they work or snake oil?
todd92
Gas already has detergents in it that prevent the fuel system deposits.
sanpablo
Rich
Long Island, NY
I realize the question is about fuel additives. Sorry to go off topic :)
I usually think most of them are snake oil. With that said I used two that seemed to work well.
CRC intake valve cleaner on my wife's 2015 Honda CRV, GDI engine. I used it for the first time at 30,000 miles. Got a huge cloud of smoke out the tail pipe so it sure cleaned something! Used it again at 40,000 miles and no smoke at all. I figure every 25,000 miles seems to be a good interval.
Before that I used Blue Devil gasket sealer on the wife's 1999 Ford Windstar, 165,000 miles. Had a small head gasket leak. The Blue Devil worked. I was going to replace the head gaskets but the van was rusting away. Would not have cost much to do but a bit of work to do with a vehicle that would not be on the road much longer, lol
Ford Maverick Fuel additives - do they work? 718HJ+9hmzL._AC_UF894,1000_QL80_
Ford Maverick Fuel additives - do they work? zpwwih0rajlqhb2pil50
Tbone289
You should use Top Tier fuel as mentioned above, but if you want additional treatment you should select a PEA (PolyEtherAmine) additive such as Chevron Techron Concentrate Plus and Redline SL-1. These are the only ones I'm aware of that consistently show results.
paneubert
Seattle
Agree. I buy a multi pack from Amazon of "Red Line 60103" once a year and treat our vehicles.
happyfer22
Fernando
Carmel NY
2025 Maverick XLT (no GPF....)
AMSOIL PI (best)
budpalumbo
ohio
many
Some do, depending on what you're going for.
If its GDI deposits you're after, top tier fuel and varying where you buy as they all use slightly different additive packages and quality synthetic oil (there are some on market made for GDI engines) seems to make a difference, at least the last papers I read.
Engine design including the pcv system, and driving habits are still the biggest factors. I haven't been doing nearly the amount of cleanings as when they first came out.
ripperAZ
AZ
2022 Mustang MachE 2021 Genesis G90 2032 Mav
PEA products like the Chevron Techron bottles are the only ones that have ever been tested to show some benefit. Hyundai and Kia recommend them.
Tim d
Alpena
Ram
I swear seafoam makes all my small engines run better i.e. lawn mowers,snowblower, dirtbike,snowmobiles , boat etc. Have not used it in any vehicle yet.
Sovande
Alexandria, VA
2026 Maverick XLT
Direct injection engines like the 2.0 Ecoboost will benefit from some kind of intake cleaner as they will have carbon buildup in the combustion chamber. In my old Jaguar I used BG44k every 5000 miles or so and the intake was very clean. I may do the same with the Ecoboost as the cost is pretty low - $25 - and the peace of mind pretty high.
Or I may not. It's a cheap truck and I'm not overly convinced it will last long enough to matter.
DHFerguson
Ann Arbor, MI
'15 Ford C-Max, '16 Audi TT Roadster, '24 Ford F-150 Lightning Tribute
My brother used to work at a contract engine/transmission/emissions testing lab. Occasionally they would test comparable items from the 'STP aisle at the auto parts store'. He said the only one that consistently did what it said it would was Chevron Techron Fuel System Cleaner.
I put >200k miles on 2 - Gen 2 Ford F-150 Lightnings. As they got older they would develop a rough idle and maybe a miss at high (supercharger) boost. I would wait until the tank was >1/4 tank full and put in a 'treats 12 gallons' bottle of Techron. Within a very few miles it would be running as it should. My brother said the cleaned-out products would end up in the oil, so, I developed a habit of putting in a bottle of Techron just before every oil change. Worked great.
