Toinky
Toyota Tacoma
There is lots of useful information on MTC about using Forscan to make interesting and useful changes to the computer modules in our trucks. This post is not about using Forscan software or programming devices--you can find that information as a sticky in the Forscan forum.
This post is for those who don't speak hexadecimal* or are otherwise hesitant to change as-built codes (or for anyone who wants to make a quick change). I have compiled several changes you can make using "easy" (not as-built) mode. Instead of selecting a module through an as-built entry, look below it and there will be a module with the same name, but not as-built (not in all cases). Connect to that module. It's the same module, just named and accessed differently. The difference is that entries are in plain English [mostly]. Be sure to write the changes. Before doing any of these changes back up your as-built modules. Use at your own risk, of course, but these changes have all done well for me. I've included links in MTC for where more information can be found on these Forscan edits.
[*I know changing as-built modules does not require actually understanding hexadecimal--it's a figure of speech.]
Enable Traffic Sign Recognition (TSR)
IPMA:
Traffic Sign Recognition (TSR) - Speed Limit Information Function (SLIF)
Traffic Sign Recognition Mode - Camera data only
IPC:
Traffic Sign Recognition (TSR) - Disabled - Counterintuitive but important
Speed Limit Information Function (SLIF) - Enabled [if disabled you get European sign symbols]
https://www.mavericktruckclub.com/f...orscan-mod-confirmed-working.9399/post-748132
Adding Drive Modes
1. Enter ABS module and search for SDM
2. For SDM - ABS disable it
3. Depending which package you have installed enable the following if any say disabled
SDM - Mode 11 (Sport)
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
4. Check the DTC codes to see if you threw one
https://www.mavericktruckclub.com/f...-and-snow-confirmed-working.10229/post-211182
Stop being locked out of functions due to being in motion
ACM
Driver Restriction Configuration - Disabled
https://www.mavericktruckclub.com/forum/threads/for-your-safety-blah-blah-blah.35866/post-690772
"Disable" Key Fob Panic Button
No 2 press option on Mavs (that I can find; available on other Ford vehicles)
BCM (BdyCM)
Panic Alarm Mode - Lights Only
https://www.mavericktruckclub.com/forum/threads/disable-panic-alarm.21229/
Disable double honk when exiting running vehicle
BCM (BdyCM)
Double Honk on Leaving Cabine [sic] - Disabled
https://www.mavericktruckclub.com/forum/threads/disabling-double-horn-chirp.9208/post-555900
Enable ECO Coach (indicators about improving fuel economy)
IPC
Enable:
ECO Mode
Eco Coach Feature
Eco Coach with Efficient Drive Mode
https://www.mavericktruckclub.com/forum/threads/forscan-mod-–-enable-eco-coach-mode.25533/post-777948
All Windows Up/Down with Press and Hold Fob Button (Lariat only)
Enable:
BCM (BdyCM)
Global Close Initial
Global Close Vehicle
Global Open Initial
Global Open Vehicle
Global Window Close w Remote
Global Window Open w Remote
DDM
Global Window Close
PDM
Global Window Close
https://www.mavericktruckclub.com/f...nfirmed-working-lariat-only.11092/post-758399
I created this thread to help others not have to cull through all the various threads and posts with lots of replies and superfluous information. Please feel free to add to this list of Forscan edits, but it would be good to stay true to the attempt to include only instructions for easy mode.
===Addendum (submitted by others and not tested by me)===
Adjust Heated Steering Wheel Temperature (if equipped)
SCCM
Change value to desired degree in Celsius
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-780569
Adjust Heated Seats L/R Temperature (if equipped)
HVAC
[I haven't actually done this one; I have no need. However, it seems obvious that it would work.]
Enable Radio ST Animation
1. ACM
2. Under “Animation Type” change Standard Ford to ST.
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-785360
Average Speed Display
IPC
Enable Average Speed Display
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-808769
Disable Auto Stop/Start
1. Open PSCM (easy mode)
2. Disable Stop/Start
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-811352
Chris_G
NOVA
C-6 Corvette
259Maverick
CJ
PA
2024 Maverick XL AWD CP360, 4K tow
Still waiting for the new release so it recognizes my24
Kagiso
Patrick
US
2001 Toyota Tacoma PreRunner
Toinky. Wow! Thank you very much for your generous contribution. Having sign recognition will be cool. Having Sand & Mud drive modes will be super cool as I do an annual trek into the NE desert mountains of NV ever summer. Depending on rainfall amounts, roads can be tricky-either wet & muddy or soft & dusty. Thanks again!
Samcat13
Gerald
The Villages Fla.
Maverick Lariat '24'
Thank you also. Been hoping someone would do this.
MaverickMom
Amy
Bronco 2022, Maverick Hybrid XLT Lux
Enable:
BCM (BdyCM)
Global Open Initial
Global Open Vehicle
DDM
Global Window Close
PDM
Global Window Close
I wish the All Windows Open feature was on the XLT Lux. We have the all windows open on the bronco and its great during the summer to vent the car as we approach. However, I would caution people with kids to think twice about the all windows close feature. It could accidently close on their fingers.
rallyshark
Donny
GA
2023 Maverick Hybrid
Great post, I bet A LOT of people will be happy to see this one. As mentioned, many folks aren't comfortable playing with the hexadecimal settings.
Setting the factory EQ to flat is another good one for those of us playing with the audio. It is under the ACM setting. I believe it is listed as "EQ Special Modes". The factory radio cuts low bass drastically, and this will restore that part of the signal that is missing. It isn't really necessary for factory speakers, but critical if you're installing a legitimate sub.
BenTheFox150
Ben
KY USA
2024 Maverick Lariat Tremor, 1992 Miata
Thanks @Toinky, I have been meaning to get around to doing all these on my new Maverick but had been putting it off as I remember how many different threads I had to read through to do them all on my last Maverick.
Really Appreciate it!
Justin says...
Justin
NC
'22 Ranger XLT
Excellent. Hoping others with similar knowledge will contribute.
generalmgr
Wes
Clarion, PA
2023 Maverick XLT EB
IPMA:
IPC:
Adding Drive Modes
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
ACM
BCM (BdyCM)
BCM (BdyCM)
IPC
Enable:
ECO Mode
Eco Coach Feature
Enable:
BCM (BdyCM)
Global Open Initial
Global Open Vehicle
DDM
Global Window Close
PDM
Global Window Close
Auto start/stop is another one that’s easy, click on disable if you’re inclined.
