SUNDOG52
Geoffrey
Birmingham in Alabama
2024 Maverick XLT, 2015 Escape SE
Is the " Animation Type " a functional feature, or just cosmetic?
Cancunbadlands
Cancun
Cancun
So I went to San Antonio
While I was there I ordered the OBDII port conector...
#yay
Where can I start with ForScan
I'm old
Ford Maverick Forscan Ideas for Dummies (Things You Can Do Using Easy Mode) 20260405_141851
Butterscotch
2025 Eruption Green Lariat
There is lots of useful information on MTC about using Forscan to make interesting and useful changes to the computer modules in our trucks. This post is not about using Forscan software or programming devices--you can find that information as a sticky in the Forscan forum.
This post is for those who don't speak hexadecimal* or are otherwise hesitant to change as-built codes (or for anyone who wants to make a quick change). I have compiled several changes you can make using "easy" (not as-built) mode. Instead of selecting a module through an as-built entry, look below it and there will be a module with the same name, but not as-built (not in all cases). Connect to that module. It's the same module, just named and accessed differently. The difference is that entries are in plain English [mostly]. Be sure to write the changes. Before doing any of these changes back up your as-built modules. Use at your own risk, of course, but these changes have all done well for me. I've included links in MTC for where more information can be found on these Forscan edits.
[*I know changing as-built modules does not require actually understanding hexadecimal--it's a figure of speech.]
Enable Traffic Sign Recognition (TSR)
IPMA:
Traffic Sign Recognition (TSR) - Speed Limit Information Function (SLIF)
Traffic Sign Recognition Mode - Camera data only
IPC:
Traffic Sign Recognition (TSR) - Disabled - Counterintuitive but important
Speed Limit Information Function (SLIF) - Enabled [if disabled you get European sign symbols]
https://www.mavericktruckclub.com/f...orscan-mod-confirmed-working.9399/post-748132
Adding Drive Modes
1. Enter ABS module and search for SDM
2. For SDM - ABS disable it
3. Depending which package you have installed enable the following if any say disabled
SDM - Mode 11 (Sport)
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
4. Check the DTC codes to see if you threw one
https://www.mavericktruckclub.com/f...-and-snow-confirmed-working.10229/post-211182
Stop being locked out of functions due to being in motion
ACM
Driver Restriction Configuration - Disabled
https://www.mavericktruckclub.com/forum/threads/for-your-safety-blah-blah-blah.35866/post-690772
"Disable" Key Fob Panic Button
No 2 press option on Mavs (that I can find; available on other Ford vehicles)
BCM (BdyCM)
Panic Alarm Mode - Lights Only
https://www.mavericktruckclub.com/forum/threads/disable-panic-alarm.21229/
Disable double honk when exiting running vehicle
BCM (BdyCM)
Double Honk on Leaving Cabine [sic] - Disabled
https://www.mavericktruckclub.com/forum/threads/disabling-double-horn-chirp.9208/post-555900
Enable ECO Coach (indicators about improving fuel economy)
IPC
Enable:
ECO Mode
Eco Coach Feature
Eco Coach with Efficient Drive Mode
https://www.mavericktruckclub.com/forum/threads/forscan-mod-–-enable-eco-coach-mode.25533/post-777948
All Windows Up/Down with Press and Hold Fob Button (Lariat only)
Enable:
BCM (BdyCM)
Global Close Initial
Global Close Vehicle
Global Open Initial
Global Open Vehicle
Global Window Close w Remote
Global Window Open w Remote
DDM
Global Window Close
PDM
Global Window Close
https://www.mavericktruckclub.com/f...nfirmed-working-lariat-only.11092/post-758399
I created this thread to help others not have to cull through all the various threads and posts with lots of replies and superfluous information. Please feel free to add to this list of Forscan edits, but it would be good to stay true to the attempt to include only instructions for easy mode.
===Addendum (submitted by others and not tested by me)===
Adjust Heated Steering Wheel Temperature (if equipped)
SCCM
Change value to desired degree in Celsius
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-780569
Adjust Heated Seats L/R Temperature (if equipped)
HVAC
[I haven't actually done this one; I have no need. However, it seems obvious that it would work.]
Enable Radio ST Animation
1. ACM
2. Under “Animation Type” change Standard Ford to ST.
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-785360
Average Speed Display
IPC
Enable Average Speed Display
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-808769
Disable Auto Stop/Start
1. Open PSCM (easy mode)
2. Disable Stop/Start
https://www.mavericktruckclub.com/f...-you-can-do-using-easy-mode.44179/post-811352
74 68 61 6E 6B 20 79 6F 75
Ya - been doing hex for over 40 years :computerrage:
Cancunbadlands
Cancun
Cancun
IPMA:
IPC:
Adding Drive Modes
SDM - Mode 4 (Sand)
SDM - Mode 5 (Mud)
SDM - Mode 9 (Eco)
ACM
BCM (BdyCM)
BCM (BdyCM)
IPC
Enable:
ECO Mode
Eco Coach Feature
Enable:
BCM (BdyCM)
Global Open Initial
Global Open Vehicle
DDM
Global Window Close
PDM
Global Window Close
SCCM
HVAC
1. ACM
IPC
Any other update? Any extra ForScan mods discovered lately?
Dad
I understand there is a iOS version for FORscan, but there are some differences in comparison with the Windows version. Can anyone tell me if I can do the same modifications using the iOS version as the Windows version? I've looked at the Comparison page on the FORScan web site, but it referred to functions whose meaning I don't understand. I don't have a PC running Windows, but do have iOS device. I really don't want to buy a PC just for FORScan.
Cancunbadlands
Cancun
Cancun
BrandenD87
Branden
Kentucky
2025 Ford Maverick LOBO
Are these only for 22-24?
