EIlig
Stefan
Los Angeles
Lariat Tremor/'69 Porsche 911E/'15Porsche Cayman
I am hoping someone has an idea for my ELM327 not connecting to my maverick. I ordered this model off Amazon and I downloaded the drivers fine. I get 1 red light and then nothing more when I connect to the mav.
I also went through to the website below and followed those directions. The device shows up in the Device Manager and while I run Windows 10, I also changed compatibility to Windows 7 and still nothing. I then downloaded the free Software to test if ELM327 is working (via this site) and all lines were green meaning it was connected. http://www.totalcardiagnostics.com/...elm327-usb-cable-on-windows-and-obd2-software
I have unplugged everything and replugged again, restarted, and still nothing. I am thinking my next bet may be to buy the more expensive programmer below to see if it works.
Oh, Maverick Lariat version also, no luxury. Any other ideas out there? thanks to all,
I have the ELM327 connector and it worked just find for adding ECO and SPORT modes to my TREMOR... Now how do we turn off the Start/Stop function???
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
Does FORScan void your warranty?
Does the programming last after disconnecting the battery and reconnecting?
Golfsnob
St Augustine
2023 Maverick XLT AWD 2.0
I have made a multitude of changes to my 2023 Bronco with Forscan. It's not as intimidating as it sounds. I'm going to plug in to the Maverick for the 1st time today and just look around and see what's available to adjust.
TrailMaster
Western Colorado
02 Ranger XLT 4L, Honda Valkyries (2)
Gonna make the plunge! I'm sure this may be debatable, but is there a general consensus on which scanner is the best one to buy, bang for the buck and features wise? Will my old Dell Venue Tablet running Windows 11 suffice for running the the software?
grumpyunk
tom
georgia
If you are dollar limited, this one is low buck, and recommended by FORSCAN:
https://www.aliexpress.us/item/3256...71505524!sh!US!193763300&gatewayAdapt=glo2usa
I bought, and checked that it worked.
This is also available from the big river site. Above is supposed to be the MFG web presence on aliexpress. I think.
This will connect via USB to a PC/Laptop, but you need to down load a driver which I cannot remember the name of.
TrailMaster
Western Colorado
https://www.aliexpress.us/item/3256803335592908.html?spm=a2g0o.store_pc_allProduct.8148356.2.767b7686WTUTwi&pdp_npi=3@dis!USD!US $40.00!US $25.20!!!!!@210318cf16961641839832331e9529!12000034771505524!sh!US!193763300&gatewayAdapt=glo2usa
Ended up getting this one, but purchased it from an American supplier on Amazon so it cost a bit more. Oh, well.
Irving
George
Virginia
None
Does anyone know if you can adjust the speed at which your seatbelt chime starts?
I had a 22 mav and the chime didn't start until 15mph, I now have a 23 mav and the chime starts at 5mph. sometimes I just drive down the street to pick up my daughter and don't even go over 15 mph, I would like to set this back to 15.
yes, there is a setting for something like seatbelt chime country. Changing that to EU makes the Chime start at 13 mph.
Jorah_L
Jorah
Fort Mill, SC
2023 Lariat, 2013 Maxima, 2009 V-Star 1300
And yes, I know most people just put everything on auto, but I personally get pretty annoyed when someone is just sitting in their car across from me and is just shining their bright ass headlights into my face the entire time or doing that into a shopping plaza.
Curious if you ever learned more about how to suppress the autolamps. I found this on the online version of the manual, and it seems to say that the daytime lamps don't turn on until the truck is in Drive, but I've no way to confirm the change personally, since I can't put it in drive and watch it at the same time!
The daytime running lamps turn on when all of the following occur:
KenJ45
2022 Ford Maverick XLT 2.0L Ecoboost
Oh I've turned daytime running lamps off completely in the settings. I'm talking about the actual headlight switch for the actual lights as in driving at night. It starts on auto by default, I'd prefer if it started in off as I like to manually switch on my lights myself.
cboy
Carlos
Puerto Rico
Mini cooper 2009
Where is the master google doc spreadsheet with all the hex numbers?
Been lurking around and searching all over but it seems to be missing. Only link I found had the document deleted.
