Step by Step for tire size change
Toronto_Maverick
Toronto
2023 XLT + Lux + 4k + BAP
Hi all,
I've got a 2023 XLT right now and went with a 235/50-18 size tire which I love the look/drive of it. The circumference is 4.5% smaller than the stock tire, and now speedo and odo are both going up 5% high...which is great because 'look how fast I'm going....oh...'
Driving 130km/h = 120-122km/h.
I've been able to change the tire diameter in the main module, however I'm struggling with the 're-learn' to force the next modules to utilize the new reading and can't figure out that step.
Anybody have a step by step (I know this may be very simple for some) of how to force the re-learn to the new tire size for the modules that pull the value off the main?
Aaron
FL
25 Lariat AWD HYBRID
From Skynet:
Here’s the straight version of how people usually get a 2023 Maverick to sync the new tire size across modules using FORScan:
1. Set the new tire diameter
• Go to ABS Module → Configuration and Programming → As-Built
• Change the tire circumference/diameter line to your corrected value.
• Write it.
2. Write the same value to the BCM
• BCM → As-Built
• Update the tire size entry there to match the ABS value.
• Write it.
3. Run the service procedure
• Go to Service Functions → “TCM/PCM/ABS Reset or Relearn” (the exact name varies by build).
• The Maverick typically uses the “PCM Reset”, which forces the powertrain and cluster to pull all current values from ABS/BCM.
• Run it.
• Cycle the ignition fully off for 30 seconds.
4. Cluster update
• Most 2022–2023 Mavericks pick up the new tire size from ABS after the resets.
• If not, go to IPC → Configuration and confirm it reflects the same number.
• If it doesn’t, write the matching value.
5. Final ignition cycle
• Turn the truck off.
• Open the door (forces module sleep).
• Wait ~30 seconds.
• Restart and test the speed reading.
Toronto_Maverick
Toronto
Perfect thank you! Will try that this week!
710-oil-614
Cal
2025 Hybrid AWD Lariat
Would be curious to know if these would also apply to a 2025? I am going to be going from 225/55/19 to 235/55/19 and would like to adjust accordingly.
deputylynch
Cheswick PA
Ford F-150 waiting on 24 Maverick Hybrid
I have a 2024 Maverick Lariat that's speedometer is off and I can't get anything to change when using Forscan!
My original circumference was 2238 and I went down to 1900 and up to 2500 and it didn't change anything!
I didn't get any codes which I guess is a good thing but it also doesn't change anything?
I'm pretty sure I followed everything above except rebooting the TCM since I can't find that.
When I made the changes, I rescanned and it shows the new value, but again nothing changes on the truck; like I didn't do anything at all.
HELP!!
Quest
You would also need to relearn AWD if its 4x4
Grammaton
Ross
Covina, CA
2023 Ford Maverick AWD Lariat BAP 4K CP360+Assist
I use "FTE-Tire Size Calculator - Forscan V5" to set my circumference in Forscan. Make a copy first to save in your Google My Drive. Generally this works for tires that don't go over 29" in circumference. For instance on my truck I set my Forscan value to 2240 that got from the FTE Calculator for tire size 255/45/20.
So for your tire sizes 225/55/19 it would be 2218 and for a 235/55/19 it would be 2251 to start with in Forscan.
Cap
Reseda,Ca
2025 Maverick XLT
Have you done this yet? I'm going to do this also on my 2025 XLT. I'm not to worried about a slight MPH difference. I live in SoCal where everyone rarely do the speed limit anyway.
710-oil-614
Cal
I haven't yet...just been too lazy to download latest Forscan version and go do what I need to for this, double honk, seat belt minder, and off road screen as well as off road and LOBO modes.
Damn, typing that out might be the motivation I need to get it done sooner than later.
