huunvubu
coppell tx
2023 Ford Maverick Hybrid
Is there any way to make the Hybrid Maverick default Driving Mode "ECO" using FORScan?
It is an annoyance to have to change from "Normal" to "ECO" on every drive and sometimes I forget and have driven part of the way before I realize it isn't in "ECO" mode.
Snax
North America
I second this!
Eagle11
Valley of the Sun
I used Forscan on my 2013 F-150. I turned on the DRLs, added Navi, added 3 blink lane change, changed the center display, removed satellite radio…
The problem is you need to know what all the codes are and what to change them to.
I got my Maverick loaded so I shouldn’t need to change anything.
Over the years many manufactures have come up with ways to make it easy to do this. Carly is one, if you own a European car, it's very easy to add those and many more features to cars.
aspect
BC, canada
XLT Lux FX4 2.0 4k
I won't say it's impossible, but....it's very, very unlikely.
psklenar
Pat
Connecticut
2022 Rivian R1T
I wonder if Ford can go all Tesla on us and "correct" these changes while we're all snuggy in our beds at night?
This is the big question I also have regarding all this Forescan talk. Not necessarily whether Ford would change settings back to default over night, but if you take the vehicle in for service, might the techs be instructed to reset altered cars to default?
Is the car's warranty information in the owners manual? I'll have to review that ... I wonder if they've included language along the lines that the s/w is merely licensed to us and that we are prohibited from making modifications ... thinking of the current John Deere cluster-f***.
pat----
Eagle11
Valley of the Sun
pat----
I can only speak for BMW, I have "coded" extra features into all of my BMW, the current BMW has many coded features, and never had an issue with BMW with it. The only time it was an issue was when BMW tech had to "update" the software of the car, which meant, I needed to recode the car, which took 20 minutes.
I've never had the dealership say anything about all the extra features I had coded into the cars.
Maverick2022XL
name
hinterlands
pat----
If the Tech has to program modules for any reason unless they back up your settings they can only reset it to the as built defaults tied to your VIN. You are ultimately responsible for those mods not the dealer so you should have backups already made for the modules you altered or a spreadsheet of the changes to put them back manually. Also Ford dealers use software called IDS and far as I know forscan back up files of module settings are not compatible with IDS.
bdaniel230
Daniel
Middleton, Id
2022 Ford Maverick XLT -Hot Chili Red - 4k Tow Fx4
I love ForScan. Used it on my Bronco to disable the double-honk when no fob is inside, enabled the global close for the windows (close windows from the fob), and added Sport driving mode (First Edition doesn't have it by default... here's the before and after of that change):
This is stock -7 Driving modes: Normal, Eco, Slippery, Mud/Rut, Sand, Baja, and Rock Crawl):
This is how it looks now - now I have all 8 modes:
You don't need to buy an Extended License - you can get a trial one and keep renewing it only when you need to edit something, too. All this change took was changing one digit of the ABS module, and restart the Bronco. It took me all of about 5 minutes to do.
I am hoping the options for what can be modified on the Maverick are as plentiful. :)
So if you select Rock/Crawl, which I would like on my Fx4, does it actually do anything like set a lower transfer case range, less transfer slippage? Not sure how that works in the non-locking diffs.
vabchusa
Va Bch, VA 23452
2020 Ford Escape Titatium, 2022 Maverick First Edition
Timers.shop has "Ford drive mode module for the F-150 that keeps you in the last drive mode you were using. Maybe something like this would work for the Mav
jjplus5
2018 Ram Power Wagon
I am hoping someone has an idea for my ELM327 not connecting to my maverick. I ordered this model off Amazon and I downloaded the drivers fine. I get 1 red light and then nothing more when I connect to the mav.
Ford Maverick FORScan 101 - Step-by-Step How to Start Guide 1651508636944
I also went through to the website below and followed those directions. The device shows up in the Device Manager and while I run Windows 10, I also changed compatibility to Windows 7 and still nothing. I then downloaded the free Software to test if ELM327 is working (via this site) and all lines were green meaning it was connected. http://www.totalcardiagnostics.com/...elm327-usb-cable-on-windows-and-obd2-software
I have unplugged everything and replugged again, restarted, and still nothing. I am thinking my next bet may be to buy the more expensive programmer below to see if it works.
Ford Maverick FORScan 101 - Step-by-Step How to Start Guide 1651509330645
Oh, Maverick Lariat version also, no luxury. Any other ideas out there? thanks to all,
Chris_G
NOVA
C-6 Corvette
I bought the one listed on the bottom of your post.
noticon75
Manhattan, KS
17 Ford F250, 15 VW Passat,
I can't find any information on this nor I'm not sure if this is the right thread to ask. But when I try to register for FORScan it says I answered the question wrong. Not sure what I'm supposed to answer!!! Any idea?? Thanks in advance!
Gullzway
OK
1968 Ford Mustang Fastback
I bought this one for $35. Enabled TSR with no issues.
Vgate vLinker FS OBD2 USB Adapter for FORScan HS/MS-CAN Auto Switch
Gullzway
OK
I know registration was closed a month or so back due to server location, may still be.
You should still be able to download and install the software. Then get the free 2 month license by filling this page out
https://forscan.org/support/prepare_trial_el_request.php?lang=en
Mavonorder
Pete
Camry
Hows your adaptor working... Have you been able to add and delete functions without any issues? I'm looking to buy a scanner. Thanks!
