Actually - they probably discovered or due to inventory supply issues used a beefier CV axle then they intended to at the start - and realized the extra cost if they kept going with it.
Can't have that!
Oh - there's that pallet of cheaper CV axles that were actually spec'd - those will work just fine!
I wonder if there was a conversation with someone in the office...
"Ted, you know how on the Maverick you said you could save $50 per truck after the 1st production job, by just using the axles we already used on other vehicles and claimed the specs should allow it to work just as good - well, got some bad news for you. All the warranty replaced axles using the same ones mean that whole $50 is very upside down as we get even more warranty replacements. We had to go back to the original run versions. Ted, pack up your things..."
"But Bob, I said they wouldn't last, and you approved it anyway!"
TREX10
Toni
Houston, Texas
2011 4Runner 4x4, 2003 Tacoma PreRun, 2005 Liberty
can't answer the lifted question, because I'm lowered. but I will say my dealership has never commented on my modifications. actually, neither of them. I bought from a dealership 10 miles away and because it's so convenient and they have done me well, I've also used another dealership for service that's almost literally across the street (3/4 mile).
I am curious about your first repair, sounds like under factory powertrain warranty. did you uninstall the lift, get the CV axles replaced under factory powertrain warranty... and then reinstall the lift?
if that is what you did I am afraid you're probably going to have to remove the lift again if you want it covered under the CSP as you kinda set a precedent for it.
or you could just pay out of pocket for tremor cv axles and see how much better they hold up.
I dropped the truck off at the dealer on Wednesday and heard back today that axles were placed under the drive train warranty. No mention of the lift.. nada. My build date was Dec '21, so it met the CSP but he'd never heard of it. I gave him a copy. I guess that means I've still got a set in reserve?
They have another item to check out, so hope to have it back next week.
The half shaft CSP is a ONE TIME REPLACEMENT!
TREX10
Toni
Houston, Texas
Nice that you know how to use all caps. Did I hurt your feelings?
Why is the CSP even required if it was covered by my drive train warrany? Seems it would continue to be replaced when it goes again, as long as the warranty is still valid.
TREX10
Toni
Houston, Texas
I think @MakinDoForNow is pointing out that if you had them replaced under the CSP then that is your 1 time replacement. If it was done under the standard warranty you might have another replacement under the CSP. By bringing it to the dealer's attention if they submitted it as a CSP replacement then you are out of pocket in the future. The CSP is not unlimited replacements for 10 years. I don;t think @MakinDoForNow was intending to be rude or shout as you might think. I think the caps was for EMPHASIS.
Well, reading comprehension is tough too I see.
I stated in my post that the dealer told me that they were REPLACED UNDER THE DRIVE TRAIN WARRANTY.
That is what prompted the comment of having a replacement IN RESERVE.
Yes, I am well aware of the CSP being a one time replacement.
The csp states it is a one time only, but maybe the 3/36 or 5/60 could be used without the knock sensor pib code, and then use the free warranty extension of the csp???? However I suspect the replaced set would be the newer version and would not be covered during the extended time period of the csp but have their own replacement warranty conditions. What's interesting is the six month extension of time the csp gives those who have over 150k miles on Sept 1, 2025.
TREX10
Toni
Houston, Texas
Polite conversation is TOUGH TOO I SEE. What he told you and what was submitted to Ford for reimbursement may not be the same thing.
I believe my truck fit the CSP requirements but apparently, the dealership has not received the CSP on my truck yet. Therefore, per the CSP, even if you haven't received it, they will still replace them if they are bad. This is my second set to crap out - I hope these last.
The dealer replaced 2 CV Axles and hardware under warranty:
2 CCPZ*3B477*G Retainer nut
1 SZ6Z*3B437*B Shaft Front axle
1 SZ6Z*3B436*C Shaft Front axle
Zero cost to me. Fingers crossed they hold up.
mspmms
2022 XL Ford Maverick 🇺🇸
I'm replying to myself, I know.
But I just got confirmation that my work is being done under factory powertrain warranty and not this CSP. And, it's expected to be done today, having gone in yesterday, so they got the parts in one day. I have no idea if it was overnight shipped (doubt it), local depot, or they already had some axles inbound anticipating needing them.
@colinl -
I have a question - please see my post here => link
pnav
california
for those who had the half shafts replaced did you have any problems at the dealership? called one dealer and they said it would cost me $192 to diagnose it. even though i have the letter and my truck does exhibit the conditions stated.
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
The diag fee will only be charged if the CV axles is NOT the problem. There’s a 95% chance that it is the cause of the vibration. But they have to cover themselves just in case it isn’t. Until they actually verify the vibration they can’t guarantee that what you’re describing is what ford is describing. You might know what you’re talking about. But THEY don’t know thst you know.. Again, the charge only applies if it turns out that what you’re experiencing is not what is being described in the recall.. remember, they have not driven it yet. But you can reasonably be assured that you won’t end up having to pay anything once all is said and done
WildHorse
Benny
DE
I asked my dealer to have front halfshaft and driver side seat buckle replacements while doing oil change yesterday. But when I pick up my truck, I only saw the invoice of oil changed without mentioning any of the CSP service items. And those two notices are still open in my Ford App. I asked them and was told that they checked and thought they were fine but kept the items open so I could get service again if I had issue in the future.
I got a feeling they didn't do the work and were just bulls**ting me. What's your experience? How do you guys think?
Darryl
Darryl
Tallahassee Florida
[/QUOTE I may be mistaken, but I believe the seat belt buckle is replaced only if necessary. If the recall has an N in it, it's replaced only if the customer has a concern and it fails inspection, . The CV axle is replaced only IF there are symptoms. At any rate. They would be on a SEPARATE INVOICE because they are warranty items whereas the oil change is a customer pay item. I cannot attest to the seat belt buckle. But if the vehicle was not exhibiting any symptoms that would describe in the field service action, they were still inspected because whoever does the oil change also does a visual inspection underneath the vehicle. So no special notation was needed on the invoice in your case. If parts have been replaced, there would be a separate warranty invoice. Some customers want a copy, others don't really care since they didn't pay for it. But again there would be no need for an invoice for the CV axles if there was no complaint of the vibration that is caused by a warrant CV axle
mspmms
Both shafts were replaced per Ford CSP 25N09 on 11/17/25.
2022 Hybrid XL with 41,150 miles / part list here =>
link
