Finding the elusive jack points on a '25. (pictures? and getting it on jack stands))
dochawk
doc
Las Vegas
This is probably because I'm missing something obvious, but . . . where in the blazes are the jack points on a '25?
I can see from the diagrams in the manual roughly where they should be, but when I crawled under, I couldn't find the arrows that are supposed to be pointing to them (per the manual).
I have my jack, four jackstnds, oil, filter, torque wrenches, impact hammer, and such standing by, but . . .
My plan is to loosen the lug nuts, put the jack and puck on the pinch weld midway between wheels on each side, and get it up on all four.
So where are these mythical points? a picture from underneath would be really useful!
Escapologist
Niagara Region, ON
They're just kind of by the nicks in the drip rail, behind front wheelarch, in front of rear wheelarch.
RodT
Rod
Lobo
I can't offer you any photos but the arrows you're looking for are actually just triangle indentations on the bottom surface of the rockerpanel. Take a rag and clean the lower surface in the areas mentioned above in post #2. The triangles are there. You're just overlooking them.
Hot Runr Guy
West Chicago, IL
dochawk
dochawk
doc
Las Vegas
I looked into those, but it's hard to justify the cost for just a few months I ha untilve multiple lifts on hand . . .
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
If you can't find the arrows, just look for the pinch area where there are 3 layers sandwiched instead of 2. That section is stronger and designed to hold the vehicle weight, and the 2-layer part is questionable, especially at the front.
JRADD
Jerry
Muskego Wisconsin
2010 Mustang Convertible, 2024 Maverick XLT
Someone had posted using aluminum tape on pinch weld location for the jack. Once you find them that makes it much easier to find them the second time. Especially if it is dark out and you need to change a tire.
Mavman1
S/E Pennsylvania
2025 Maverick XLT Hybrid AWD 4K Luxury Trim Oxford White
Here are two photos from under my 25 Hybrid XLT showing the triangles (aka arrows per the Owners Manual). They are on the underside of the rocker panel surfaces.
Front left:
Ford Maverick Finding the elusive jack points on a '25.  (pictures? and getting it on jack stands)) 1774122616404-7x
Left Side Rear:
Ford Maverick Finding the elusive jack points on a '25.  (pictures? and getting it on jack stands)) 1774122705660-uh
Mavman1
S/E Pennsylvania
Just curious about the type and weight rating of your four jack stands that you have as I need to get some also. How do you support the pinch weld using the jack stands? Is there a pinch weld support/adapter that fits on the top of the jack to make it secure?
Pointyears
South Central PA
Chops
Lobo
Front left:
Left Side Rear:
I put a piece of grit tape on mine to feel the spot better when positioning my jack.
Unfortunately the pinch weld is not long enough to position a jack stand on the pinch weld while the Maverick is jacked up on the pinch weld?
Hot Runr Guy
West Chicago, IL
