EONR24
Swag
United States
2024 Ford Maverick XL
Hello everyone!
EDIT: CHECK OUT MY OFFICIAL FORSCAN MAVERICK SPREADSHEET HERE!
I finally found the way to disable the ANNOYING Seatbelt information screen that comes on when you start the truck and stays on even after you buckle your seatbelt. Thank you to @ZOODAD over on the F250 forums for the coding information. THIS SUPER DUTY spreadsheet he put together might be useful for future MAVERICK FORScan Mods. THIS IS CONFIRMED TO WORK FOR ALL 2022-2024 MAVERICK TRIMS!
DISABLE SEATBELT INFORMATION SCREEN
1. Open IPC AS BUILT
2. Change line 720-13-01 and 720-13-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
3. Change line 720-14-01 and 720-14-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
These changes remove the seatbelt info screen pictured below entirely and it also disables the seatbelt chime too. I would love to hear from other members to see if these changes work in your Maverick! Tested on my 2024 Maverick XL AWD ECOBOOST with the smaller instrument cluster. (The 4 inch Instrument Cluster)
EDIT: ALTERNATIVE CODINGS to keep the seatbelt minder (chime and dash light) but disable the seatbelt monitor (information screen) are linked HERE , HERE and HERE !
ALSO, Here is a link to 2 more changes that DISABLE DOOR AND KEY CHIMES and I went ahead and listed them below! I have successfully tested both of these coding changes!
Let me know if these codings work for your Mavericks out there!
DISABLE DOOR CHIMES
1. IPC AS BUILT
2. Go to 720-01-02
3. Replace the third digit with a "0" as shown here
xx0x-xxxx
4. Write the changes and let Forscan correct the checksum
DISABLE KEY-IN IGNITON CHIME
1. IPC AS BUILT
2. Go to 720-01-02
3. Replace the sixth digit with a "2" as shown here
xxxx-x2xx
Ford Maverick FINALLY, FORScan coding to disable the Seatbelt Information Screen! (CONFIRMED WORKING) FORScan coding to disable the Seatbelt Information Screen!
Ford Maverick FINALLY, FORScan coding to disable the Seatbelt Information Screen! (CONFIRMED WORKING) IMG_2898
Ford Maverick FINALLY, FORScan coding to disable the Seatbelt Information Screen! (CONFIRMED WORKING) Screenshot 2024-03-24 at 1.14.40 AM
Ford Maverick FINALLY, FORScan coding to disable the Seatbelt Information Screen! (CONFIRMED WORKING) Screenshot 2024-03-24 at 1.14.58 AM
EONR24
EONR24
Swag
United States
Beat me to it! Same. Cheers for finding and sharing this one!
Awesome thank you for trying it out! Great to hear that it works! After finding no information and just threads of endless nonsense on the seatbelt menu, I started trying coding from other fords with the same or similar seatbelt menu. Do you have the 4inch or 6.5 inch instrument cluster? Just curious if this works on the 6.5 inch cluster too!
OrCoaster
Dale
Mid Coast Oregon
81 VW Caddy and 96 Ford Ranger
I have the larger screen in my Lariat and will swat that nagging seatbelt nonsense this weekend.
Brixil
Houston
2024 Lariat Maverick
6.5 for me.
I think the problem has been twofold. On one hand there are a bunch of people who mistake the seatbelt chime (easily fixed by doing the physical procedure to deactivate) for the seatbelt popup (unknown fix until now) and on the other there are a bunch of ignorant people who criticize anyone attempting to solve both these annoyances.
Shieldwf
Randy
Pennsylvania
2023 Maverick XLT Off-Road 4k Tow
Ok so my belt is on. What good is obscuring my instrument cluster with giant splash screen showing a green check mark? For like 10 minutes! Is that to reward me for being a good boy? If that screen disappeared as soon as you fastened your belt I bet nobody would care.
CurtisB
2023 Maverick XLT Hybrid
In my 2023 XLT Hybrid, I get in, I put the key in and turn it, the screen shows I need to buckle up, I buckle up, within 3 seconds it goes away. Never had the annoying issues others have seen.
EONR24
EONR24
Swag
United States
That’s great. But on the 2024 it locks you out of your menu, at least on my 4 inch screen it does. 2023-2024 F250 owners have this menu literally get stuck on and pressing ok does nothing to get rid of it.
EONR24
EONR24
Swag
United States
Ok from what read here thus far minis the insults is one can remove the “check screen display” ,I’m ok with , yet keep the initial beep, I’m ok with that
I Want that ,yes?
I can’t understand your comment. Right now i am working on an optional change that will keep the chime and the seatbelt dash light but still disable the seatbelt information screen. Not sure if it’s possible yet.
