- First Name
- Swag
- Feb 26, 2024
- United States
- 2024 Ford Maverick XL
- Engine
- 2.0L EcoBoost
Hello everyone!
EDIT: CHECK OUT MY OFFICIAL FORSCAN MAVERICK SPREADSHEET HERE!
I finally found the way to disable the ANNOYING Seatbelt information screen that comes on when you start the truck and stays on even after you buckle your seatbelt. Thank you to @ZOODAD over on the F250 forums for the coding information. THIS SUPER DUTY spreadsheet he put together might be useful for future MAVERICK FORScan Mods. THIS IS CONFIRMED TO WORK FOR ALL 2022-2024 MAVERICK TRIMS!
DISABLE SEATBELT INFORMATION SCREEN
1. Open IPC AS BUILT
2. Change line 720-13-01 and 720-13-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
3. Change line 720-14-01 and 720-14-02 to ALL ZEROS. And WRITE the changes. Click yes to let Forscan correct the checksum.
These changes remove the seatbelt info screen pictured below entirely and it also disables the seatbelt chime too. I would love to hear from other members to see if these changes work in your Maverick! Tested on my 2024 Maverick XL AWD ECOBOOST with the smaller instrument cluster. (The 4 inch Instrument Cluster)
EDIT: ALTERNATIVE CODINGS to keep the seatbelt minder (chime and dash light) but disable the seatbelt monitor (information screen) are linked HERE , HERE and HERE !
ALSO, Here is a link to 2 more changes that DISABLE DOOR AND KEY CHIMES and I went ahead and listed them below! I have successfully tested both of these coding changes!
Let me know if these codings work for your Mavericks out there!
DISABLE DOOR CHIMES
1. IPC AS BUILT
2. Go to 720-01-02
3. Replace the third digit with a "0" as shown here
xx0x-xxxx
4. Write the changes and let Forscan correct the checksum
DISABLE KEY-IN IGNITON CHIME
1. IPC AS BUILT
2. Go to 720-01-02
3. Replace the sixth digit with a "2" as shown here
xxxx-x2xx
DISABLE DOOR CHIMES
1. IPC AS BUILT
2. Go to 720-01-02
xx0x-xxxx
1. IPC AS BUILT
2. Go to 720-01-02
xxxx-x2xx
