Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight
Administrator
Administrator
Staff member
MTC
Fords
Since this has been a frequently asked question, sticky'ing this info for easy reference:
WHEELS
The 2022 Maverick's factory wheels specs are:
Size: 17x7" or 18x7"
Width: 7" width
Offset: +37.5 mm
Bolt Pattern: 5x108
Center Bore: 63.4
Thread Size: M14 x 1.5 lug nuts
Note: these are the same specs as the Bronco Sport wheels
Standard Wheels:
  • XL: 17" Steel Wheel Painted Sparkle Silver (27.2 Lbs - source)
  • XLT: 17" Painted Aluminum Wheel
  • Lariat: 18" Bright Aluminum Wheel
Optional Wheels:
  • 17" Painted Aluminum Wheel [XL & XLT]
  • 17" Unique Aluminum Wheel [FX4 Off Road Package for XLT & Lariat]
  • 18" Black Painted Wheel [Lariat]
TIRES
The 2022 Maverick's tire brands and sizes are:
Continental Procontact TX - [Standard on XL & XLT]
225/65R17 A/S [standard]
225/65/R17 A/T or 235/65R17 A/T [optional]
Michelin Primacy All Season A/S - [Standard on Lariat]
225/60R18 A/S [Optional on FX4 Off Road Package]
Comparison:
225/65R17 A/S [XL & XLT] vs. 225/60R18 A/S [Lariat or optional on FX4 Off Road Package] - posted below by @MAVRICK
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight 0xsb1emofvn71-png
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight 0eb6kxhxfvn71-png
oljackfrost
Minnesota
What about the dimensions of the optional 17" wheels with machined face the come with 235's?
Same wheel specs, larger diameter tires.
Leadphinger
Eric
Lincoln, NE
2022 Maverick XLT, FX4
I don't see how...look at the wheel center of the black ones on the FX4 vs the machined 17's...the offset is clearly different as the bolts are nearly flush with the face of the wheel but the machined wheels are recessed from the face of the wheel.
Can anyone verify the actual dimensions or post a photo of the back of the wheels where the offset and dimensions are stamped?
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight 2CE9BD58-D341-48E7-BC50-C5A612ED07B3
vezpa
EMG
IL/IN border
Too many to list.
Its an optical illusion caused by the larger, beefier tires. They are the same offset.
MAVRICK
Any
2024 XL
Comparison of 225/65R17 A/S [XL & XLT] vs. 225/60R18 A/S [Lariat or optional on FX4 Off Road Package] - via Reddit
04mach146
Brad
Chevy Tahoe, dodge eco-diesel
Comparison:
Looking at continental website they don't offer a Continental Procontact TX in a/t or any all terrain tire at 225/65r17 they do offer TerrainContact™ A/T in 225/60r17 is this the actual tire on our fx4 mavs? Or is it the perrelli scorpion a/t in 225/65 r17 ? Just curious trying to decide if I will look into new tires or not to have ready.
To be honest I'd rather have the continental terraincontact over the perrelli
JKinPA
York, PA
07 Mountaineer
I hope they change from Pirelli. You might be fine in the sunshine state, but they are garbage in snow. They handle wet and dry okay, look good, but are ice skates in the frozen stuff. I am planning on switching them out immediately. I didn't get AWD FX4 to slide around this winter. Hate spending the money but Falken and Cooper make some really good A/T tires that aren't horrible price wise, plus I may jump up to the 235 from the 225. Add some beef and height.
04mach146
Brad
Yeah I was just looking at Falken on tirerack says it's the original equipment...
Ford Maverick Factory Tires Sizes & Wheels Specs For 2022 Maverick: Width, Offset, Bolt Pattern, Center Bore, Thread Size, Weight Screenshot_20210929-211933_Samsung Internet
That being said this is the wrong size from what ford says for the xlt...
JKinPA
York, PA
07 Mountaineer
It will fit, a little beefier but not that much to cause an issue
Ok It appears that the procontact TX in 225/65/R17 has at least 2 I'd numbers (different production runs?) I found drilling down from "not your size? Click to find yours" procontact TX box. So since the TX line are at least initially new equipment tires no one has bought them in this size before and not sold retail yet.
See the TX reviews in 2020! https://tirereviewsandmore.com/continental-procontact-tx-reviews/
04mach146
Brad
I'm looking for a/t as I'm an fx4 guy procontact TX isn't a all terrain tire it is all season so not what comes on my vehicle. When I said the not my size comment it was what tire rack gave me as oem I didn't choose a tire size just put in my vehicle info
Jim graham
Deltona fl.
WHEELS
Width: 7" width
Offset: +37.5 mm
Bolt Pattern: 5x108
Center Bore: 63.4
Thread Size: M12 x 1.5 lug nuts
Standard Wheels:
Optional Wheels:
TIRES
Comparison:
I read the owners manual and I thought it said the bolt nut was,14mx1.5
