Just to specify, that's with tires right?https://www.msn.com/en-us/autos/new...-deep-dive-39-mpg-and-1-twist-beam/ar-AARlaIW
Stock XLT hybrid wheels weight 49lbs.
Only if it's way out of spec, like a 0mm offset or the likes. Then the warranty could be voided for things like wheel bearings and such. Just my opinion.Does changing tire size affect warranty?
Lug torque 148 lb.ft (200 Nm)Does anyone happen to know the lug nut torque specs for the factory wheels?
Using other Maverick or Bronco Sport Wheels, how do you delete and re learn the TPMS ?
Can this be done without going to the dealer or tire shop?
For tire relearn w/key ignition: Start with key Off, press and release brake, cycle from Off to Run 3 times ending on Run, press and release brake, cycle from Off to Run 3 times ending on Run. Horn will chirp. It is now in Learn mode.
For push to start: Push and release brake, press Start button 5 times, push and release brake, press Start button 6 times. Horn will chirp. It is now in Learn mode.
From there you start at the driver's front tire and go clockwise slowly adding/removing air until the horn chirps. I've never particularly had luck with that on newer Fords. The TPMS reset tool from Ford has always been reliable for me and is fairly inexpensive. I haven't tried the even cheaper aftermarket knockoffs.
148 lb ft is nominal for a 14mm class 10.9 fastener. 85-95 is more for 1/2" or M12 size.YIKES! Lug torque 148 lb.ft - that seems high. Tire Rack mentioned 85 to 90
Thank you for the info !148 lb ft is nominal for a 14mm class 10.9 fastener. 85-95 is more for 1/2" or M12 size.
Probably already mentioned, the catalog does show 17x7, and 18x7I ordered a "full size" spare, I know the tire is only a 215/60. Could anyone please let me know if the rim is indeed 7" width and 37 offset like the ones that are mounted?
Thanks for any info on this, I have still time to drop it from order, am getting it for the rim to mount the correct tire size on.
Ford workshop manual states 150 lb-ft of torqueYIKES! Lug torque 148 lb.ft - that seems high. Tire Rack mentioned 85 to 90
This site shows:Are the torque specs correct ? This is for M12. I thought the Maverick was M14 1.5
| Newton-meters | Foot-pounds |
| 200 Nm | 147.51 ft-lb |
