EGR Valve Location for 2.5L Hybrid? Engine Code P0402
ryanram0s
Ryan
2022 Ford Maverick Fx4
Does anyone have a picture or know the location of the EGR Valve or DPFE sensor. Check engine light appeared on an XLT 2.5L hybrid with less than 240 miles.
Frustrating that my local Ford hasn't called back.
SuperDave71
Carthage IN
Ford F-350 CCSB 6.7
If you look on the back side you can see the exhaust manifold with an insulated pipe coming up to the egr valve on the drivers end of the intake
Maverick2022XL
name
hinterlands
Also check your coolant levels. If they are low that can also potentially throw a P0402 DTC code.
EasyMaverick
Any chance, would you be able take a pic of it? I'm experiencing the same issue as the OP and may attempt a diy repair, however, I'm not exactly sure of the egr location
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
I doubt you still check this lol from 2022. But I 2nd the request for the EGR sensor photo
Quest
You should have it check as other things can also cause that code to set
The gasket arrow is pointing to it
Ford Maverick EGR Valve Location for 2.5L Hybrid? Engine Code P0402 EGR
Ford Maverick EGR Valve Location for 2.5L Hybrid? Engine Code P0402 DPFE
Ford Maverick EGR Valve Location for 2.5L Hybrid? Engine Code P0402 Backpressur
Joaquin F
Joaquin
LA
2022 Mav Hybrid XL
