Doing brakes yourself
Mavidiesel
New England
2022 Ford Maverick XLT 2.0 Ecoboost AWD
Anyone else on here done the brakes themselves on their Maverick? My local garage wants $1000 an axle. I’m thinking I can do a lot better buying the parts and doing it myself in the driveway. Can anyone tell me what you need for parts from rock auto and what you need for tools? Anything specialized?
MavChris
Macomb Michigan
23 Maverick XLT, 22 Bronco Sport, 19 Flex SEL
Just curious how many miles you have?? I checked my brake pads at 25,000 miles and lots of life left in both the front and rear pads. I do believe that you don't need any special tools, however you need to set "brake service mode" to replace the rear pads. Do a search on "replace brake pads" on this forum and you will get other owners who have replaced their brakes.
MavChris
Macomb Michigan
Some EcoBoost owners reported having trouble activating brake service mode. Have any idea if this is still an issue?? Thank you for posting the documentation!
zen_
24' XLT
I haven't done the Maverick yet, but I have done at least a half dozen brake jobs myself.
Using RockAuto parts, I would get the Powerstop Geomet coated rotors + Akebono pads. If you want to do the job right, also wire wheel the hub surface to remove any crud, and re-grease the caliper slides.
mcluvin
CR-V
I swear the further north you go, the bigger the grift. My daughter paid $500 in Virginia for rear brakes. I called around too. Everybody was $500. I know road salt does its damage, but that's just so crazy to me. I went ahead and did her fronts when I visited. Good Akebono pads are ~$60. I generally put ~200K miles on my rotors before I replace them, and when I do replace they are like $30 to $40 each. $1K is nuts!
Joester
UPSTATE NY
2022 Maverick ECO, FX4, 4K, 2023 Bronco Sport, 2024 Escape Red Line
I'm at about 48.5K miles and it's looking like I'll be doing them come spring. For the extra cost of the rotors, I'll be doing them too (rear has some wear lines in the middle so they would need turned).
A job I'll do myself for sure.
Gamma500
2022 XLT
Never did a Maverick brake job but did many others. The last one was two years ago on a Dodge Charger. I used high end pads/rotors and total cost was $500 for all four including slider seals and anti-rattle clips. That’s at crazy inflated Canadian prices.
I think $1000 per axle is ridiculous. The garage must be planning on a full days labor to change two brakes.
Definitely do it yourself or get prices from other garages.
skinnyboy
Andy
Ontario, Canada
My '22 hybrid seems finicky. Have had it work no issues, but one time it was reluctant.
Cheers.
Tim d
Alpena
Ram
That price is crazy! Can I ask how many miles on your maverick?
Tim d
Alpena
Ram
Our pads also look almost new at 31,000 miles.
GmanGM
Garry
Baltimore
Dakota
Nice to see here it’s a normal brake job except the Service mode which is now also pretty normal. I am a bit disappointed not to have seen a response from a high milage hybrid user here with milage info so I could see if I can expect to go 90k before changing pads. Defining hybrid vs EB is critical due to the large impact regen braking has. My hybrid Escape went 90k before a brake job and then it was a normal job. My 83k hybrid Chevy Volt never had a brake job before I sold it. Hope my hybrid Mav does the same. Rotors will rust/wear uneven and thus may need to be replaced w pads- crazy you can’t find someone to turn them anymore.
Sig-vicious
US
2024 Maverick XLT Tremor
Might be time for me to get a controller that will execute the brake service/maintenance mode. My Subaru needs it as well, I didn't want to invest $300-400 on an OBD tool, so I bought all the rotors/pads myself. Did the front brakes myself, and then handed the rear parts to a friendly shop and they did the rear for $150.
Theoretically the tool would pay for itself in 2 uses. Anybody know how expensive of an OBD tool to pull off the Maverick's brake maintenance mode?
GmanGM
Garry
Baltimore
Dakota
Great question! Me too!
