DIY - Tow Hitch Installation
Devildog1
VA
2023 Maverick XLT
Thanks for the hitch write-up, great detail. Just got the fascia removed, but 4 retaining clips popped off and I'm not sure from where? Anyone know where they came from?
Ford Maverick DIY - Tow Hitch Installation clips
Adospeed
Adospeed
Ado
Colorado
Hybrid in Shadow Black
Check your messages...
riveraca
Carlos
Puerto Rico
Maverick XLT
Hello Maverick members!
Posting another option for a custom Hitch. Of course I recommend to buy yours with the factory one, but for those who did not, here is the story:
-Paid $150 to a local machine shop (with my drawings) + Hitch tube ($18) + Connector ($16) from Amazon
-3/16" steel
-(4) 304 SS 1/2" Bolts with Lock Nuts ($20)
-Rated at 3,540 lbs. with a 4x Safety Factor
-3 hrs. installation time
Ford Maverick DIY - Tow Hitch Installation h
Ford Maverick DIY - Tow Hitch Installation ha
Ford Maverick DIY - Tow Hitch Installation hc
Ford Maverick DIY - Tow Hitch Installation hd
Ford Maverick DIY - Tow Hitch Installation hf
Ford Maverick DIY - Tow Hitch Installation hg
Ford Maverick DIY - Tow Hitch Installation hh
Ford Maverick DIY - Tow Hitch Installation hi
aaustinbrown
Austin
2022 XL EcoBoost; 2024 XLT, Lux., CP360 Hybrid
-3/16" steel
Any help on the install of the wiring? Planning to do this myself this weekend.
riveraca
Carlos
Puerto Rico
Maverick XLT
Any help always welcome! Thanks!
I ordered the Tekonsha Trailer Hitch Wiring from ebay. Seems plug & play for Maverick. Just battery and ground, all other connections with factory style connectors!
Adospeed
Adospeed
Ado
Colorado
@riveraca @aaustinbrown Can you be more specific on what you need help with, is it routing of wire, or did your kits not come with instructions?
riveraca
Carlos
Puerto Rico
Maverick XLT
Thank you! Kit came with instructions and it was basically a plug-in system! I installed it last weekend in less than an hour. So at this point all done!
Now in the look out of a new trailer for 2 ATV's!!
c5turbo
AZ
2022 Mavrick Hybrid
Seems like a lot of work but that looks far better than anything else I've seen.
How wide is the rear crash bar in the 'sandwich' direction?
riveraca
Carlos
Puerto Rico
Maverick XLT
Width is 2 inches. I added 1/16" clearance for easy installation. Removal of the crash bar was not necessary but removing the bumper fascia took 30 mins.
Ford Maverick DIY - Tow Hitch Installation HS
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Hot Runr Guy
West Chicago, IL
-3/16" steel
Very nice workmanship & design, but can I ask how you arrived at your rated weight value?
HRG
Adospeed
Adospeed
Ado
Colorado
@Adospeed I have the same question. Could you share your knowledge again? Thank you.
@tngarren
.......Thank you and glad they helped. Gosh, I can't recall where those would be from, but as I was looking at my pictures, I came up with the following - I would say take a look at:
1. Along the "wings" of the fascia, where it attaches to the wheel liner, pic attached. You can see similar clamps.
2. Or at the rear right side of the truck where the bumper fascia attaches to a plastic box-like piece.
Ford Maverick DIY - Tow Hitch Installation IMG_20220219_093559451
Ford Maverick DIY - Tow Hitch Installation IMG_20220219_093419487 (1)
Ford Maverick DIY - Tow Hitch Installation IMG_20220219_093549401
riveraca
Carlos
Puerto Rico
Maverick XLT
HRG
Engineering calculation of the machined part. But remember the towing limits of the truck shall be respected!
J C Bellamy
JC
Pickens, SC
2022 Ford Maverick XL
Got around to installing the Ford Tow Hitch on my truck.
I did not install a 4 pin connector yet. It's not hard, it's just tedious because of all the screws you are removing. I am attaching a PDF so that if anyone wants to use it as a baseline, or eventually develop one with 4 pin connector install, feel fee. ***This is for sharing purposes only, and I'm not a technician, so I don't take any responsibility for your DIY efforts.*** My personal note, if you are mechanically inclined, you can do this.
